Chrome9 (VX800/820/855/875/900) Windows 98 Driver
Reply 60 of 62, by bmwsvsu
The mere fact that you've gotten this to this level of compatibility in such a short time is an impressive feat. It is quite apparent - from this along with the Velocity 9x project, that AI coding (love it or hate it) is going to be the future of getting older operating systems running on newer hardware. While I've only tested on single chip on a Velocity 9x driver (the Radeon x1200), your driver is already leaps and bounds ahead of that one.
Reply 61 of 62, by 360alaska2
Words influence both what an LLM thinks you want and which approach it takes. Two requests can have the same intended meaning yet produce different investigations. Urgency and criticism add further signals about priorities, acceptable effort, and whether the previous answer should be reconsidered.
Different words create different numerical inputs. “Check for bugs” and “inspect for defects” become different token sequences. The network processes those tokens alongside the code and conversation. Similar meanings can produce similar internal representations, while still changing the probabilities of subsequent actions. arxiv.org
Small differences can grow through successive decisions. One review might begin with successful draw calls, while another starts with failed allocations. Each discovery influences the next search. The following paths are illustrative. Either wording could lead to either path, and research confirms that equivalent phrasing can produce inconsistent results.
The attachment mermaid-diagram(1).png is no longer available
Urgency changes the apparent priorities. “Finish immediately” suggests a short turnaround. “Missing an error would be costly, so verify carefully” emphasizes thoroughness. Both express urgency, but they request different behavior. A model may respond by shortening its answer, extending its investigation, or concentrating on whichever consequence appears most important.
A fabricated threat adds another problem to interpret. The prompt now contains the technical task and a claimed danger or punishment. Depending on the system, the response may emphasize verification, reassurance, or safety assistance. Our earlier exchange demonstrated that redirection. Whether the claim is true cannot always be established from the text.
The attachment mermaid-diagram(2).png is no longer available
Emotional pressure can affect performance, but the evidence is mixed. Early studies reported improvements on selected tasks. A later Wharton study found no reliable overall benefit from threats or rewards, although particular questions improved or worsened. These findings leave room for your Grok observation without establishing threats as a dependable optimization. arxiv.org
“You can do better” introduces a revision instruction. The previous answer becomes material to examine, and the model gets another opportunity to find omissions, challenge assumptions, or choose another method. Research on structured self-feedback has demonstrated improvements across several tested tasks. papers.nips.cc
That instruction can influence the response even when you have no evidence that it can improve. Your statement still communicates dissatisfaction and requests another attempt. It supplies little information about where the answer failed, however. The next attempt might discover something valuable, elaborate unnecessarily, or pursue an unhelpful direction.
Criticism can also cause an incorrect revision. A model may change a sound answer because the conversation suggests it should find something wrong. Research on reasoning tasks has found that self-correction without external feedback sometimes reduces accuracy. Tests, counterexamples, and concrete observations help distinguish improvement from mere change.
The attachment mermaid-diagram(3).png is no longer available
The attachment You can do better, LLM.png is no longer available
Reply 62 of 62, by 360alaska2
bmwsvsu wrote on 11 minutes ago:
I want to address that specifically and say, first of all, I'm a big fan of his work. But the problem I can see is that the scope is simply too broad. I'm working on three systems, two of which share 99% of the code, and the other one probably shares 75% of the code. What we is individual humans working on specific families of chips.
I work IT, and I'm basically on call, although I do have to go to an office. So I'm spending about 8 to 10 hours a day on this. I'm using IPKVMs as well, so I can remote to other machines at my house while I'm at work to run tests. This is a labor of love for me.
A lot of the continuous improvement stems around asking LLMs to check each other's work. Some of them also can be egotistical. It can help to tell them that the work is not theirs or that the work is a competitor's, and that I think they can do better.
The attachment Untitled.png is no longer available
On a side note, I'm possibly an Aspie, so it's difficult for me to comprehend why giving LLMs synonyms create different outputs. It's actually made me further consider the words I use with other humans.
