Windows 98 - Sound Drivers installed but no sound
Reply 60 of 60, by Shiftyy
TheMysteriousGray wrote on Today, 13:08:
Shiftyy wrote on Today, 09:14:
If you're looking at a different motherboard, I recommend considering an Advantech AIMB-742 over the DFI G4E620. Way cheaper and readily available on Aliexpress. Same amount of ISA slots. I didn't have any issues with mine other than it can be picky about which PSU you use. The picture of the PCI/ISA IRQ assignment I supplied earlier was from that board. I still have it but don't need or use it anymore.
Interesting. They all look like they cost roughly the same as this board did, so I guess it’s worth pursuing.
On a different note, I’ve heard good things about using VSBHDA to get DOS sound through PCI cards. I know it’s emulation and thus not perfect, and it ONLY works in pure DOS, but it seems very compatible. Do you have any experience with it?
No experience unfortunately. I run real hardware for almost everything. You can see my build log here.
