Timing patches
Reply 60 of 71, by Qbix
Rank DOSBox Author
DOSBox Author
wouldn't we risk with this patch that pc speaker games get their timer disabled ?
afterall some commands are send to both the speaker and the timer in this patch
Water flows down the stream
Reply 61 of 71, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
pcspeaker has its own implementation of the timer which is only controlled by the PCSPEAKER_SetCounter(p->cntr,p->mode) call in write_latch. The functionality of write_latch is not changed by the patch.
1+1=10
Reply 62 of 71, by Qbix
Rank DOSBox Author
DOSBox Author
do you have some specs of that gate2 thing ? (specificly describing the link between the pcspeaker and it. I can find the gate 2 in the intel specs on the timer, but not it's linking to keyboard port)
The two patches related to the timer look correct. Will have to test that reload thingie with some demos although it is probably correct
Reply 63 of 71, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Hmm, did you get my PM? Looks like it was lost?
1+1=10
Reply 64 of 71, by Qbix
Rank DOSBox Author
DOSBox Author
I didn't get your pm.
Did you get mine ?
Reply 65 of 71, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Yes. I'll write it again...
1+1=10
Reply 66 of 71, by Qbix
Rank DOSBox Author
DOSBox Author
great. I'll edit this message if I got it.
edit: got it
Reply 67 of 71, by wd
Rank DOSBox Author
DOSBox Author
Before that have a look at the outbox/sent folder.
Reply 68 of 71, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
It's not there, that's why I thought it got lost. (It said something about my session being invalid but apparently succeeded on the second try which it did not). I'm writing the message again now...
1+1=10
Reply 69 of 71, by Qbix
Rank DOSBox Author
DOSBox Author
Commited overscan, reload, bcd and gate2(modified)
Reply 70 of 71, by jcdutton
Why not just use gettimeofday() instead of INT8 ticks?
ticks seem to no stay accurately in time over the whole day.
Reply 71 of 71, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
An attempt at the midnight issue...
1+1=10
