Reply 60 of 220, by ux-3
The Voltage for the PCI cards needs to be created oncard from the 5V line. That produces a lot of wasted heat inside the case. A V3 AGP card expects to be fed 3.3V through the AGP port. If you are lucky, the board delivers those 3.3V directly from the power supply. If not, an onboard regulator does the job, and will likely fail when it meets a V3 3000. Well known problem of the time.
If you want a low power PC, just take something like an ASRock K7S41gx with an AMD Geode, fall back on 200 MHz FSB and undervolt to minimum settings. You'll draw about the same you can get with a P2, but have a lot of computing power available.
