Bit of an overdue update on the Cyrix build. I've decided on the final setup for this bad boy, which is the following:
-Cyrix C3 1GHz underclocked all the way down to 133MHz(according to the BIOS, at least. For some reason, I can't get this CPU to run any faster. If I bump up the FSB speed of the motherboard, it resets back to 66MHz. This CPU performs VERY well with its cache disabled, though most of my DOS games are a bit choppy with the cache disabled, so I'd need to speed up the CPU)
-64MB of RAM
-80GB hard drive(I know it's overkill, but it was the smallest I found lying around)
-Matrox Millennium II graphics card
-Yamaha YMF744 sound card hooked up through SBLink(I actually wired my SBLink cable wrong when I first put the cable together, and this was why the computer would crash when using the YMF744 through SBLink. Oops!)
-Soyo SY-6BA+ motherboard with Intel 440BX chipset
-Sony 24X CD-ROM drive
-OS is Windows 95 OSR2.5 set to boot into MS-DOS 7.10(as this is a test box, I had to install Windows 95 as some DOS drivers for my sound cards rely on the Windows drivers)
Now, I want to know something: my YMF744 works wonders under DOS, but it doesn't work well with Doom. When I boot Doom, the game crashes while loading. I don't remember the exact error message, though. However, if I play the game without sound effects, it works perfectly fine. This issue actually affects many of my PCI sound cards under DOS.
Also, I posted about this in the Marvin section of the forum but never got a response: why does my YMF744 have an obnoxious ringing noise in the right audio channel whenever I use it under Windows? This doesn't happen under DOS at all, which I really don't understand.
Lastly, is there some way to get the XG synth on the YMF744 working under DOS? Or will I have to hook up my CM-300 to the YMF744 for General MIDI?
Now to find a nice Socket 7 motherboard for my AMD K6 and/or a good 486 motherboard where I can fit a 486DX4.
Creator of The Many Sounds of:, a collection of various DOS games played using different sound cards.
