Reply 60 of 69, by Ozzuneoj
- l33t
wrote:As @Jo22 has mentioned @Ozzuneoj, DOS is a read-only operating system and what I as well like very much about it. Unlike Windows that changes/updates files according to the hardware you're using. In my opinion there's a possibility that there are parameters in your 440BX BIOS that need to be changed in order to 'eat' the CF card and boot normally. You may also want to try to disassemble your CF adapter from the computer that it works on and to assemble it temporarily in your 440BX in order to verify whether the card is tied to a specific CF adapter model or not, which may cause it to not boot correctly on a different system that it wasn't installed on in advanced.
By the way, now that I think of it, you mentioned that you aren't able to boot from the CF card on a 440BX motherboard. Are you by any chance using the same motherboard (Intel SE440BX-2) that I'm having the same issue with?
I guess I wasn't real clear on what I'm doing.
I'm using an internal CF card reader front panel on my main system (i5 2500k, P67, Windows 10), and that's where I'm moving all the data around. The card worked in an old Gateway 2000 430TX+K6 233Mhz system using a basic CF->IDE adapter. When I move the whole cable+adapter+card over to my Wintec W6BXA 440BX system, it hangs at Verifying DMI Pool Data. I've tried changing all sorts of settings and nothing has fixed the problem. Any idea what specific BIOS settings might cause this? There are hardly any settings on the 430TX system (since it is an OEM board), and it just works. This 440BX board has a TON of settings though.
I did try doing a full disk copy from the Maxell 400x card I was using over to a Sandisk Ultra 333x card and it does the same thing on the 440BX system.
One thing I did discover in Windows 10 though, is that right clicking the removable drive in "This PC" and choosing Eject (or doing it through Disk Management) seems to actually let you reinsert another card in the removable drive almost immediately, where as using the "Safely Remove" taskbar icon seems to disable\remove the entire removable drive, which requires a system restart for it to read another card. This should make playing with CF cards MUCH easier.
EDIT: Also just tried using an 80-wire IDE cable, just in case that was an issue with the newer board (not likely since it is still very old) and it made no difference. Every one of the 80-wire cables I own has a blocked pin and of course this board HAS that pin, so I just poked a hole in the blocked cable end with a thumb tack. 😀 Tricky, but made no difference...
EDIT2: Of all the weird things... I've been playing with it more and when I change the type of drive for the CF card to "NORMAL" rather than LARGE or LBA, it gets stuck in the same place except it prints a lower case "j" on the line before hanging there. Strangely, I'm able to CRTL-ALT-DEL to reboot when it does this, where as I have to use the power button to shut the system down when its set to Large or LBA. Maybe I'm on to something... I just don't know what.
