Reply 60 of 188, by Bill90
i have to agree 100% will never be possible with soundfonts are just samples collection files after all.
IMO Bassmidi sounds alot closer to my old SBlive Value (before the drivers got all buggy) but pitchbend/modwheel is way better on Fluidsynth
i made a recording of my soundfont with the above midi test file (thanks it was really helpful)
still off from the real thing
https://www.dropbox.com/s/vmx13lxjrd3s63q/mas … 20test.mp3?dl=0
Reply 61 of 188, by realnc
DracoNihil wrote:
realnc wrote:
FluidSynth sounds better than BASSMIDI. That also means it's gonna sound different.
If by "sounds better" you mean better resampling and interpolation methods, then you misunderstand what I have gripes over fluidsynth. The last time I tried FluidSynth from the stable version I could grab off of SourceForge, most soundfonts (like the standard ones off of Creative AWE32/64 Live! and so on cards) are played differently in FluidSynth than a real EMU chip or BASSMIDI. And by played differently I mean parameters in the instrument patches themselves are handled differently in FluidSynth enough to cause me to detest it.
I was judging merely on how it sounds to me. Playing a MIDI file in FluidSynth sounds better to me (subjectively) than in BASSMIDI. Although that says nothing about whether it plays it correctly, so you might very well be right.
I also don't think SoundCanvas SoundFonts can work 100% because doesn't the SoundCanvas employ some actual synthesis methods during the lifetime of the voice? Stuff you can't really do with a SoundFont? Correct me if I'm wrong...
I have no idea 😜
In any event, FluidSynth is what I can use anyway now, since I've switched to Linux as my main OS and BASSMIDI doesn't seem to be available (which is very very strange, since there's Android and OS X ports, so a Linux port would be trivial 1-day work.) I'm not gonna boot into Windows every time I want to play a MIDI file or fire up DOSBox.
Reply 62 of 188, by gdjacobs
I'm in the same boat. I found something that may offer a solution, but I haven't had a chance to try it.
https://bitbucket.org/kode54/bassmidi_synth
Reply 63 of 188, by Danfun64
IMO, the SC-55 Preset soundfont sounds like Scc1t2 but with added echos, which seems to make the soundfont less accurate than Scc1t2. Are any of the samples different (more accurate)?
Reply 64 of 188, by autoexecdotbat
would any one be able to use a rom extracter to get the rom samples out of the orchid soundwave32 and make a soundfont out of those?
to win the game you must defeat coppa!
http://chng.it/DNc2L8LvLJ
Reply 65 of 188, by lybxlpsv
try turning off the reverb and chorus on bassmidi. althou the soundfont sounds seems kinda different imo too compared to the real sc-55.
hmm, using lsb function in bassmidi for roland gs midi playback seems to be quite interesting https://www.youtube.com/watch?v=4heEI0y75-o
http://dl.lybxlpsv.com/files/dropzone/asdf.png
Reply 66 of 188, by autoexecdotbat
could someone make a soundfont of either of the following sound cards/modules:
any OPL4 based soundcard
kerswiel pc88
ensoniq soundscape
roland cm64 with snu110 expantion card
yamaha mu2000
yamaha fb01 default presets
orchid soundwave32
wince_gm.dls
the fm/sample hybrid synth on some old mobile phones
akai sg01v
es audiodrive fm patch set
Reply 67 of 188, by Bill90
I think the CM64 is in the same boat as MT-32 (a soundfont of it would not be very useful)
Reply 68 of 188, by lybxlpsv
well you weren't supposed to play native CM-64 midi on a soundfont. it's only useful for certain GS midi that requests CM-64 presets at Bank 127.
Reply 69 of 188, by autoexecdotbat
OK, so that's out of the question.
Reply 70 of 188, by lybxlpsv
autoexecdotbat wrote:
for mu2000, well it has loads of presets, also alot of the preset requires modulation and require customized bassmidi player for the LSB part.
the closest you can get is that DB50XG on the homepage with bank 1-124 mapped to the 1-124 lsb and bank 125 mapped to bank 64 msb. but it still lacks modulation for XG effects and sample is only 22khz. Or sample it from S-YXG50/S-YXG100 PVL althou it is time consuming due to lots of presets.
and OPL4? maybe this http://hp.vector.co.jp/authors/VA024632/ ?
yamaha fb01, theres kontakt sound library for that (and probably some certain VST but not sure if it has the default presets).
wince_gm.dls, since theres no app that can open that file, maybe try get Windows CE sdk/emulator and sample it from there? last time I've tried Windows Mobile SDK, it can run ARM compiled apps without problems
Reply 71 of 188, by badmojo
could someone make a soundfont....
Does spamming the internets with requests for people to do stuff actually work? Coz I got a whole list of stuff here that needs doing.
Nice work OP! I'm in a sound font frenzy at the moment so am looking forward to trying these out.
Reply 72 of 188, by Bill90
well the request for the Cards samples kinda makes me think it wasnt for GS use xD
Reply 73 of 188, by Synthoridity
[snip]
Trying to make soundfonts out of those would be extremely tedious and nigh impossible without direct access to the samples. The GM banks used by various devices like that may be stored in ROM, or in a unique file format for which no editor exists.
Also note that some GM banks simply cannot be accurately recreated in soundfont format, due to using synthesis or features not supported by SF2.
Cards which use GM banks in a known file format (e.g., DLS format 1 or 2) are the "easiest" to work with when making soundfonts.
Reply 74 of 188, by autoexecdotbat
OK, how about doing a soundfont of the aureal vortex 2. My question is: does it use the same gm dls as the montego? also, would it be possible to do a soundfont of either the multisound or the tdk PCI soundcards? both of those cards used the same chip as the awe32.
Reply 75 of 188, by Bill90
i can confirm the the vortex 2 has the same ARL bank that is already around and converted (still have the driver CD)
many of thos midi devices is going to take alot of effort as in
(A) get a PC that can use the sound card and sample each note /implying that person has a working one on hand
(B) ripe the Rom samples /still have to figure out all the setting for each instrument layer /even with that there are alot of features soundfont do not support sense it was made with Emu hardware in mind.
Reply 76 of 188, by autoexecdotbat
the OPL4 instruments were already ripped in fast tracker format, so you could use those as a starting point. link is on the topic "old soundfonts hard to find"
Reply 77 of 188, by leileilol
can anyone make me these sound fonts for me IMMEDIATELY:
pc speaker
pc peizo speaker
instrument names TTS (names of instruments spoken by microsoft sam)
speak & spell
floppy drive
epson printer
long live PCem
FUCK "AI"
Reply 78 of 188, by realnc
Or needed. Munt already emulates these quite nicely.
Reply 79 of 188, by autoexecdotbat
woops, forgot about that.
