Apple QuickDraw 3D Accelerator Card
Reply 60 of 71, by Gona
stynx wrote on 2022-05-21, 15:45:
I just tested "Virtual Wings" and the Version 1.0.2 is compatible with the QuickDraw 3D accelerator. It runs pretty smoothly and […]
I just tested "Virtual Wings" and the Version 1.0.2 is compatible with the QuickDraw 3D accelerator. It runs pretty smoothly and has textures (that seem to be working).
Tested games with 100% support so far:
- Virtual Wings
- Havoc
Games that work with texture errors:
- Nanosaur
- Weekend Warrior
Games that don't work:
- Tomb Raider (1 &2) -> not recognized
- Quake 1 - RAVE patch -> Error 10 Freeze
- VR Soccer -> not recognized
- Mech Warrior 2 -> not recognized
- Nascar Racing -> not recognized
- Quake II -> Open GL/not supported
- IndyCar racing -> not recognized
- HotCarts -> not recognized
- Descent 1 & 2 -> not recognized
- Unreal -> not recognized
Gremlin's Virtual Pool has a QD3D version bundled with some 6500 machines "Virtual Pool 3D", it might be worth a try.
https://archive.org/details/virtual-pool
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 61 of 71, by dr.zeissler
recently bought such a card...using/testing it in my 7300PPC mac OS8.
Reply 62 of 71, by dr.zeissler
Interesting would be the comparison between the QD3D card from apple against the onboard ATI solutions apple offered back in the day? (Ati Rage Series etc.)
Reply 63 of 71, by stynx
dr.zeissler wrote on 2023-11-18, 11:01:
Based on my benchmarks, i would say the Rage and Rage II would have been slower than the Apple 3D accelerator card in real-world scenarios. The main problem is that the Apple 3D card is not capable to actually compete in real world scenarios since too many features are missing. Especially the limited texture memory will make a comparison impossible but in terms of polygon-throughput it is very capable. The 3Dfx Voodoo is about 3-4 times faster than the Apple 3D card in raw benchmarks and 2-3 times faster in more realistic scenarios. A three-card setup would be able to barely match the Voodoo but the 33MHz 32bit PCI-bus is not capable managing the amount of small DMA transfers needed to fully use the potential.
A 2-card setup of QD3D accelerators would be as fast as a basic Rage Pro.
Speculation:
In terms of performance it would be capable to run Quake @640x480 in the region of 10-15fps (above Rage II levels) but since a lot of features are missing and some features like lightmap would have used up 2 rendering cycles, it could drop to Rage II levels. Since the QD3D card uses technology very similar to the Power VR, the Quake results could also be much higher since overdraw would be limited from the hardware-level. The architecture itself is quite capable and would have been a good start but the PCI-bus limitations and the artificially limited memory and texture features make it nearly unusable.
I have recently acquired a Radius Thunder 3D. The benchmark results are very disappointing. But I only have the buggy and slow 1.0.2 driver version of that card. I would like to test the card with my setup but not in this configuration.
-Jonas
Reply 64 of 71, by diagon_swarm
Babasha wrote on 2022-05-25, 19:08:
MacOS 6 - 8.1 (are 68k only or 68k/PPC, they dont have Rave/Glide support).
MacOS 8.5 - 9.2.2 are PPC-only (they have Rave/Glide support but in native mode only, not in Classic environment under MacOS X).
I can tell for sure that 3Dfx Glide is fully accessible in Mac OS 7.5/7.6. I have both installed on my Power Macintosh 7200/75 and playing Tomb Raider in the hardware accelerated mode with a 3Dfx Voodoo Graphics.
Vintage computers / SGI / PC and UNIX workstation OpenGL performance comparison
Reply 65 of 71, by diagon_swarm
Thank you stynx so much for all your research here!
I quite enjoyed the whole thread with all the info and your measurements / comparisons. A few notes and questions below:
S3 Virge 325 (the original one) was released in 1996, but the silicon was made in 1995 and they waited for the initial release of the Direct3D (DX2) in june (?) 1996. Many developers had the cards already in 1995 and worked on S3D-accelerated versions of their games.
It seems like the chip does some sort of hardware vertex processing from your description? Is there more than just the triangle-setup? Btw 3Dfx Voodoo, Matrox Millennium II, Rage II and (any) S3 ViRGE do not do even triangle-setup in hardware. Have you tried if the vertex processing speed is sensitive to the main CPU speed of the machine?
From my measurements and findings Rage II is slower than S3 Virge when you need to push complex geometry through the card. On the other side, S3 ViRGE is very innefficient in working with textures (especially filtered ones), so which card is faster depends on the type of a 3D scene. Btw a good ViRGE DX/GX is twice as fast as ViRGE 325 in textures - thus on par with a single QD3D card in texturing (was there any ViRGE DX/GX available for Mac? Is it possible to mod a PC version of the ViRGE to a Mac version?).
Is the texture memory of the QD3D card connected using 64bit width to the graphics chip? The texturing performance is not that bad given your mention that the texturing was added not long before the release.
Btw I see heavy inspiration from the SGI systems (if I ignore similarities to the PowerVR chips). The texturing part reminds me the SGI IMPACT architecture (including the small texture memory that is more like a texture cache, where the system expects to move textures in/out as the scene is rendered).
If there are more cards, do they slip the screen using scanline interleave (like SGI Maximum IMPACT or 3Dfx V1/V2 in SLI) or other mechanisms?
stynx wrote on 2023-12-16, 13:25:
I have no experience with the Rage Pro on Mac, but later Win/PC “turbo” drivers leveraged full potential of the chip and it was on par with 3Dfx Voodoo Graphics - with about 50-55 Mtex/s (10x the original ViRGE 325). Also, the Rage Pro has full triangle-setup in hardware, larger texture cache and many things that made it significantly better than Rage II (just the mipmapping bug dragged the chip down in terms of visual quality).
Reply 66 of 71, by stynx
diagon_swarm wrote on 2024-04-02, 20:02:
The comparison is a bit tricky since the QD3D accelerator is very limited in 3D functions. It has a similar hidden surface removal tech as the Power VR. This means that a lot of polygons will not even "touched" and the card can therefore "punch far above its weight class". A two-card setup of the QD3D accelerator is very fast in real-world tests of the time and comes close to a Rage Pro and Voodoo 1. The lack of features makes it mostly unusable, though. If a lot of polygons ware drawn in a plane, a two-card setup is half as fast as a Rage Pro or Voodoo 1.
Reply 67 of 71, by marxveix
Installed Quickdraw 3D 1.5 for Windows, how to know it accelerates with Rage Pro? Quickdraw 3D Viewer works well.
30+ MiniGL/OpenGL Win9x files for all Rage3 cards: Re: ATi RagePro OpenGL files
Reply 68 of 71, by dr.zeissler
Is QD3D on Windows on any use except from the Quickdraw 3D viewer?
Reply 70 of 71, by marxveix
RaVeN-05 wrote on 2025-04-25, 14:41:
How Mac hardware can work on windows?
And even which apps /games can use it's api
Quickdraw 3D Win9x app added. There are newer dll files available what i have not tested. This is QuickDraw 3D 1.5.3.8, i also have some 1.5.4.9 files for Windows. Some quickdraw 3d extra examples added, quickdraw 3d has its own examples also included with the install. Press release of Xpert@Play has Quickdraw 3D API listed and ATi Xpert@Play is regular Rage Pro with TV out for PC, not Mac Rage Pro version.
This video has also Windows 95 with Quickdraw 3D demonstration and they also mention ATi i think, as i remember.
https://archive.org/details/wwdc-1997-306-quickdraw-3d
