Show off your tiny PCs
Reply 60 of 62, by Jed118
Here's my 200LX - got the manual and original bag for it somewhere. 4MB version too!
http://imgur.com/a/Z8udM
How do I embed the picture in the message?
What's for sale? my eBay!
Reply 61 of 62, by KingDaveRa
adalbert wrote:
PC/104 industrial mainboard with Vortex86 166MHz CPU (Pentium-compatible, speed adjustable in BIOS), 2,5" HDD mounted underneath, 128MB RAM, FDD connector, USB, VGA, 4 COM ports, etc...
I made a ISA to PC/104 adapter, so standard cards can be plugged in. You can see the size compared to a compact disc.
Apologies for resurrecting old threads. I've got a PC/104 motherboard which I'd like to make an adaptor for, so I can fit a soundcard on it. Is it really just a case of mapping pin-to-pin? My board has all the pins for 16-bit slots, so I can wire it all up if so. I've even got a small case I can fit it all in so I'll have a pizza-box 486. I've found a few riser card, but they're ludicrously expensive, and I notice the often have other components on the boards, and in many cases have a molex for power. Is there enough power in the PC/104 spec to run a Soundblaster or Soundblaster 16?
Reply 62 of 62, by pentiumspeed
Did not know what is make of this 250GB SATA hard drive in your clear plastic mini PC?
Cheers,
Great Northern aka Canada.
