Dual socket 7 build
Reply 60 of 74, by BitWrangler
DEC were always my favorites, possibly due to being able to pick them up cheap because nobody "rated" them, but they were pretty solid for me too.... until the era of dirt cheap Realteks where everything had drivers and supported them, so I tended toward them, though by then the handling of collisions and lack of freaking out in packet storms weren't a factor because it was all switches, not hubs or 10base2. Meaning if your realtek gets on well with it's port on the switch it will probably continue to do so.
Reply 62 of 74, by Intel486dx33
This motherboard was probably designed for WinNT 3.51.
By the time WinNT 4.0 came around Intel already released the Slot 1 Pentium II
And many computer manufactures and motherboard manufactures already released dual slot 1 motherboards and
Workstations. WinNT 4.0 was main stream on Pentium II.
But back in 1997 while working for a computer education company we use to run WinNT 4.0 workstation and server on Pentium 100 computers with 32mb ram. And they use to run every program available at the time. They ran vary stable and reliable.
So WinNT 4.0 actually runs fine on a Pentium 100 CPU.
Reply 63 of 74, by matze79
Sphere478 wrote on 2021-02-23, 21:34:
I hate doing that then it has all the bloat from the previous version.
Not really if you go from a clean install to next
Reply 65 of 74, by Kahenraz
This is very interesting! I didn't know that there was such a thing as a dual processor Socket 7 motherboard.
Reply 66 of 74, by Sphere478
Kahenraz wrote on 2021-12-29, 11:51:
If you think that’s interesting check out the link in my last reply :p
Sphere's PCB projects.
Reply 67 of 74, by Kahenraz
What a beast. You and the board.
Reply 68 of 74, by Sphere478
Tyan S1564 (single socket7 CPU) instability
I’ll save this link here in my dual build thread as it has relevancies to this board.
Reply 69 of 74, by Sphere478
Finally!! Some dual socket 7 over clocking!!
It was bound to happen when I ran across these identical unlocked 166 mmxs.
Reply 70 of 74, by Kahenraz
See how well you can get Quake to run in DOS and nite which resolutions are playable.
I know that having multiple processors won't help, but overlooking them is interesting.
Reply 71 of 74, by Sphere478
Kahenraz wrote on 2022-03-08, 08:05:
It was kinda a joke 🤣, the only way I can over clock this mobo is to put cpus in it that are slower haha
Got a link to the specific benchmark you want me to run?
Reply 72 of 74, by H3nrik V!
Will it run Crysis?
Oh, I meant, will it run with 75 MHz FSB?
Reply 73 of 74, by Kahenraz
Sphere478 wrote on 2022-03-08, 09:18:
Phil's benchmark is the easiest way to get benchmark results. Since it's a Socket 7, I think that Quake would be the most appropriate.
Reply 74 of 74, by Sphere478
H3nrik V! wrote on 2022-03-08, 11:06:
Will it run Crysis?
New clock gen for tyan s1564d (Research)
Maybe soon…
