Reply 60 of 147, by lepidotós
 - Member
TrashPanda wrote on 2022-11-15, 03:45:lepidotós wrote on 2022-11-15, 01:30:I'm so far winning a GF4 MX4000 PCI which is said to be on par with an original 2MX for about $17. Could be another avenue to keep in mind. Seeing as it's a really low end card for 2004, it might be easier to find as PCI than something high end as something to shove in a Dell Dimension.
I bought a GF4 MX4000 PCI recently ..got super lucky too as its one of the rare 128bit memory bus models which makes it a direct replacement for a GF4 MX440, saved me a ton of cash as PCI MX 440s tend to be expensive from the ones I have seen on eBay.
Okay, as it turns out, it was an FX 5200. I can't tell if that's better or worse, since I'm mainly interested in using this machine for DOS. I mean, either is probably more than overkill for DOS, but I suppose the DX9 support is appreciated?
Glad the MX 4000's working out for you! I see another PCI 4000, but it'd listed at $40. It's a 128MB card, though, is that indicative of bus width?
