My Youtube (videogames music) Channel: RetroGamesClub
Reply 60 of 72, by RetroGC
Nintendo DS Soundtrack - Castlevania Dawn of Sorfrow (work in progress)!
Work in progress playlist:
https://www.youtube.com/playlist?list=PL_BhbJ … JnuRkza2UIseLYE
Track 05 - Pitch Black Intrusion
https://www.youtube.com/watch?v=iL3d89PrFaw
Each channel has been recorded from Midi Files and Soundfont generated by VGMTRans (and after almost 2 years of ignored request 🙁 I've decided to manually loop the tracks, so loop point could differ a little) and lightly mixed.
My Videogames Music Channel
My Videogames Music Channel Thread
Reply 61 of 72, by RetroGC
Master of Monsters - Sega Megadrive Soundtrack!
https://www.youtube.com/playlist?list=PL_BhbJ … Mu0v-uSc9fNsWM7
Recording has been done with Real YM2612 chipset inside Nano Drive 6.
Nano Drive has been updated (according to github page, with new and right capacitors to solve YM2612 Low pass issue, despite still yet no audiophile capacitors )
Reply 62 of 72, by RetroGC
Champions of Krynn - NEC PC-98 Soundtrack!
Complete Soundtrack Playlist:
https://www.youtube.com/playlist?list=PL_BhbJ … 6Yh9V06_3AtzwjK
Track 06 - Battle-1
https://youtu.be/ZJBfguyh1NM
Track 07 - Battle-2
https://youtu.be/SYZA9pdb_0I
Champions of Krynn , Nec PC-98 - YM2203 Chipset (OPN ) . Remastered & Enhanced version.
Before recording I've mixed VGM Files to reduce SSG channels' volume output (as it is unbalanced on Real Hardware).
Recording with real Hardware, YM2203 chipset.
Reply 63 of 72, by RetroGC
Iron Seed - PC Soundtrack (Module) !
Complete Soundtrack Playlist :
https://www.youtube.com/playlist?list=PL_BhbJ … 9wc-yqdGrKfHwar
Mod files recorded trough conversion in Midi/SF2 format. Sinc 16 taps Resampling.
Single tracks recorded at 96 kHz 32 Bit, finally resampled at 44.1 kHz 16 Bit.
Special thanks to falcosoft for supporting me with mod2midi.
Reply 64 of 72, by RetroGC
Terminal Velocity - PC Soundtrack (Module) !
https://www.youtube.com/playlist?list=PL_BhbJ … TJ6LIfkeWOMhcU8
Mod files recorded trough OpenMPT with "Blackman 4-Tap 74" Sinc Resampling. (couldn't convert to MIDI this time). Single tracks recorded at 48 kHz 32 Bit (Higher rating produced even more lack on heights) and finally resampled at 44.1 kHz 16 Bit.
Reply 65 of 72, by RetroGC
Age of Wonders - PC Soundtrack (Module) !
Complete Soundtrack Playlist (Work in progress):
https://www.youtube.com/playlist?list=PL_BhbJ … qPkwfRcqDMIXHN8
Single tracks recorded at 48 kHz 32 Bit, finally resampled at 44.1 kHz 16 Bit.
Reply 66 of 72, by RetroGC
Final Fight 3 - Super Nintendo Soundtrack!
https://youtube.com/playlist?list=PL_BhbJAAue … z9mHGc1uftIpfFa
Recording: Plogue Chipsynth SFC with Native Interpolation and Minimal Filtering
I preferred these settings when recording to preserve the character and authenticity of the original hardware, despite the occasional loss of high frequencies.
Reply 67 of 72, by RetroGC
Tales of Phantasia - Super Nintendo Soundtrack ! (Work in Progress!)
Complete Soundtrack Playlist (Work in Progress, I've just published the first 5 tracks):
https://www.youtube.com/playlist?list=PL_BhbJ … MslyvD_rh7w_TFD
Recording has been done with Real Hardware: Super Nintendo PAL version, SuperCIC, uIGR & D4 Patch Mod together with Digital Audio Board output.
Digital to Analogue Conversion has been done with PCM1793 DAC.
Reply 68 of 72, by RetroGC
Supremacy - Commodore 64 Soundtrack!
Main Theme:
https://youtu.be/QED-CkM28dI
Real Hardware Recording
Commodore 64, SID 6581 CBM 4084
RF Modulator replacement video enhancement THS7316 Installed to avoid signal degradation.
Music by Jeroen Tel
I took a break from the Tales of Phantasia soundtrack.
I've to say i prefear the first SID gritty sound compared to the 8580. Not so easy to try to improve sound mantaining original SID personality.
Reply 69 of 72, by RetroGC
Cybernoid - Commodore 64 Soundtrack!
Main Theme:
https://youtu.be/peIOAdyK6Ks
Music by Jeroen Tel
I've to say i prefear the first SID gritty sound compared to the 8580. Not so easy trying to improve sound mantaining original SID personality.
Reply 70 of 72, by RetroGC
Cybernoid 2 - Commodore 64 Soundtrack!
Main Theme:
https://youtu.be/mTNLYrcejVA
Music by Jeroen Tel
I've to say i prefear the first SID gritty sound compared to the 8580. Not so easy trying to improve sound mantaining original SID personality. Please let me know what do you think about this results.
Reply 71 of 72, by RetroGC
Platoon - Commodore 64 Soundtrack!
Main Theme / Loader:
https://youtu.be/-T3smiOafg0
Stage 2 Tunnels:
https://youtu.be/o7wRLzQdnVY
Complete playlist:
https://www.youtube.com/playlist?list=PL_BhbJ … 6apSrmjXsmaif45
Jonathan Dunn
Reply 72 of 72, by RetroGC
Turbo Outrun - Commodore 64 Soundtrack!
Complete playlist:
https://www.youtube.com/playlist?list=PL_BhbJ … SE1BN7llK67Khfz
Turbo Outrun
Remastered & Enhanced version by RetroGamesClub
Music by Jeroen Tel
I prefer other Commodore 64 soundtracks. This one was a request I received on YouTube, but it definitely pushes the SID to its limits thanks to the extensive use of samples.
