Octek hippo vl+ 3.02 no POST no Beep no Code
Reply 60 of 62, by treeman
For reference I tried another motherboard on 1 address line and got a more better result on the same settings, so I think pulse view can see ok
Reply 61 of 62, by rasz_pl
treeman wrote on 2023-06-10, 01:06:
https://i.ibb.co/cYMn65G/6th.png […]
You have to zoom all the way in at the start of the sequence.
>D5 = pin 20
>D4 = pin 22
Now we can see there is D4 D5 activity after all
We know board is not starting so obviously there wont be continuous access. We are interested in seeing if there is an initial attempt to read bios - 5 byte access at FFFF0h. What can be happening:
- no activity at all, cpu might not be running at all
- few initial bytes are fetched but bios/motherboard databus is corrupted and computer immediately crashes
Reply 62 of 62, by treeman
Ok I tried the clockgen chip now to see how good the multimeter was.
Looks like you were right rasz, shows signals on 8mhz 25mhz and 33mhz
8mhz
25mhz
33mhz
D7=Refclk
So like you are saying good chance a data line from bios to chipset or from chipset to cpu or worst case chipset itself is losing the information.
No pinout for this chipset also available.
However it has been great to learn new things here, and as always im not writing it off for the 50th time ill check chipset pins and try trace a few data lines etc
maybe oneday ill stumble onto a replacement chipset too
