WIn98SE system DOS mode: EMM386 only gives 31k UMBs!
Reply 60 of 71, by Harry Potter
LSS10999: I know how to make PIF files but want to run most DOS applications from within Windows, even graphics ones--SVGA ones also--and switching to DOS mode every time I want to run a DOS program is at best inconvenient. 🙁 I wouldn't mind doing it for special DOS-based programs and situations, though. I have a DOS-based NES emulator called NESticle. It supports ModeX VGA modes and Win32 LFNs. I'd rather have it run from within Windows and simply exit it to return to Windows. Running Windows applications in the background shouldn't mess up the emulator. 😀 Jo22: I thank you for your advice. I will Google it now. 😀
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 61 of 71, by Harry Potter
I Googled Virtual PC Windows 98 and found some WIn98 emulators on modern versions of Windows but not DOS emulators for Win98. I will try a different search. 😀
Reply 62 of 71, by Harry Potter
I downloaded DOSBox, even though I already have it on later versions of Windows. It should run very fast on that system, as it has a Pentium 4 processor at I think 1GHz.
Reply 63 of 71, by megatron-uk
That isn't actually very fast. P4 processors are really quite inefficient.
Sure it isn't a P3?
Like other in this thread, I'm really not sure what you are trying to do. Run your DOS games from DOS, not Windows. Even at the time many games did not recommend doing what you are trying to do.
https://www.target-earth.net
Reply 64 of 71, by Harry Potter
The BIOS start-up screen says it's a Pentium 4. Also, most DOS programs ran fine on an old Pentium 2. I can revert to DOS for most DOS programs, though. BTW, how do I have QEMM optimize a system setup in a PIF file? I am fully capable of doing it myself but really want QEMM to do it.
Reply 65 of 71, by CoffeeOne
Harry Potter wrote on 2023-07-20, 18:58:
A Pentium 4 rated at 1GHz does not exist.
Reply 66 of 71, by Harry Potter
Oh. Sorry! 🙁
Reply 67 of 71, by Gmlb256
megatron-uk wrote on 2023-07-22, 07:03:
I know what he was trying to do, getting UMB and EMS while running Windows 98 SE. By adding LocalLoadHigh=0 in the [386Enh] section of SYSTEM.INI, all the UMB won't be taken when Windows starts.
Although there are DOS programs that doesn't work within Windows, most of those recommendations applies more to Windows 3.x than 9x. The latter fares better when running DOS applications and there are VxD drivers providing enhancements not available in pure DOS.
Harry Potter wrote on 2023-07-22, 10:27:
Make a PIF with custom CONFIG.SYS and AUTOEXEC.BAT settings that starts MS-DOS mode, from there you can optimize with QEMM after executing the shortcut.
Reply 68 of 71, by Harry Potter
Okay. Thank you. 😀 BTW, that's pretty much what I wanted. I also want utilities such as DOSKEY to start with Windows so I can use them in a DOS prompt. BTW, will Windows save the changes to the start-up files to the PIF file?
Reply 69 of 71, by wierd_w
Harry Potter wrote on 2023-04-29, 22:25:
I just looked at the output of MEM/D and found that, other than the monochrome video buffer, I only have 4k of Upper memory at CF00. I also tried MSD from the DOS prompt, and apparently, I don't have it. Where can I get it? BTW, I still have QEMM on my machine, and the Windows drivers seem to work. I was told here that QEMM has a program called MANIFEST. Will it display the Upper memory map the way you specify?
It is on the win9x install cdrom.
REMOVED
Reply 70 of 71, by Gmlb256
Harry Potter wrote on 2023-07-22, 14:42:
Yes, the changes done to both custom CONFIG.SYS and AUTOEXEC.BAT files will be saved into the PIF file after exiting MS-DOS mode.
Reply 71 of 71, by Harry Potter
Thank you. 😀
