Pulling my hair out with EGA programming.
Reply 60 of 61, by BloodyCactus
keenmaster486 wrote on 2025-06-04, 21:33:
In any case what I need is a jmp instruction to a label that is not limited to +/- 127.
then its a normal jmp (3 bytes) the assembler should choose the best one based on the distance of the jump.
;; wasm -ms -o test.asm
;; wlink file test.obj name test.exe
_CODE segment 'CODE'
start:
xor ax,ax
jmp mylabel
mov ax,1
mylabel:
mov ah,0x4C
int 0x21
_CODE ends
end
works for me. no assembly errors.
Reply 61 of 61, by mkarcher
I tried using "jmp near <label>" (actually I'm using jnz, so "jnz near") but it would not compile - said "operator is expected".
There are no near conditional jumps on the 8086. They were introduced with the 80386. Use "jz next; jmp label; next:" instead. Likely WASM also has the "jumps" directive that allows WASM to automatically generate that sequence if the target is out-of-range.
Be careful with "jumps" though: In single-pass mode, it will cause all forward jumps that are not explicitly marked "short" with this slow and bulky workaround sequence.
