Reply 600 of 683, by Kahenraz
- l33t
Is it used to any effect in Quake 2, such as animated palettes?
No, it's used for performance reasons as all Quake2 textures are indexed color, except for skyboxes where there's 24-bit versions. There's no special color remapping like Quake either.
Silent Hunter II specifically supports table fog. There's even a warning in its configuration utility that this may not work correctly on some video cards:
You can also turn table fog on/off from the in-game options menu:
So far, it has been very rare that a game outright states that it's using table fog, making Silent Hunter II pretty unique in that regard. Even more amusingly, this game was released in November of 2001.
Joseph_Joestar wrote on 2024-03-18, 09:59:Start Quake 2, enable 8-bit textures in the Options > Video menu and then open the console by pressing tilde (~). If paletted te […]
Start Quake 2, enable 8-bit textures in the Options > Video menu and then open the console by pressing tilde (~). If paletted textures are supported, the console should state that GL_EXT_shared_texture_palette is detected and used. Relevant screenshot from a Voodoo 3:
Rage 3 / Rage 4 Direct3D palleted textures are working well with right drivers, tested some time ago Rage Pro and Rage128 Pro OpenGL palleted textures also and they are not found with Quake2 , even if it is not so hard to add this function i think. Now i did try Rage128 Pro and GLDirect and version 1.0 up to version 3.0 OpenGL palleted textures are working well if i disable mip mapping option from GLDirect. I used more GLDirect 1.0, easier and less things to change, from GLDirect 2.0 / 3.0 Performance option does not work with palleted textures and CAD version is working from 2.0 / 3.0, choose this, and disable mip mapping, i disabled all other extra options. From GLDirect 1.0 multitexture seems somehow to work, but explosions are slower and i disabled it. I check Rage Pro GLDirect OpenGL also out, in theory it should work,but for Rage128 Pro it does already.
To get GLDirect OpenGL palleted textures, use the right driver version and settings from GLDirect, i used driver 4.11.6745 and 4.13.8006, probably you need to enable palleted textures from Direct3D option if not enabled by default from changed Rage128 Pro driver inf. Palleted GLDirect speed is slower than OpenGL version, Quake2 timedemo 48fps. GLDirect 4 or 5 seems not to work with palleted textures at all. Performance option is faster than normal/regular, working GLDirect 1/2/3 version shows Mesa 3.1 with Quake2. Tested, used ALTOGL, but it did not work with palleted textures, is there any other old and good DX6/7/8->OpenGL tool out there that may work ok with palleted textures? Perfomance penalty is huge, probably half the original speed, i used 640x480x16 resolution, this way both APIs are working for Rage, not only Direct3D.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Why was Table Fog such an inconsistently supported feature? On non-3dfx cards I'll typically see it referred to as Table Fog Emulation or Vertex Fog. Did 3dfx patent this feature or something?
Kahenraz wrote on 2025-01-05, 20:44:Why was Table Fog such an inconsistently supported feature? On non-3dfx cards I'll typically see it referred to as Table Fog Emulation or Vertex Fog. Did 3dfx patent this feature or something?
Vertex fog is a different thing. You can read up on the differences in this document.
As to why games from that time implemented fog in various ways, your guess is as good as mine. All I can say is that the mid-late 90s were a turbulent time for hardware development. The PDF document I linked to above states that Nvidia cards emulated table fog until the original GeForce, which could finally do it in hardware.
Joseph_Joestar wrote on 2025-01-05, 20:55:Kahenraz wrote on 2025-01-05, 20:44:Why was Table Fog such an inconsistently supported feature? On non-3dfx cards I'll typically see it referred to as Table Fog Emulation or Vertex Fog. Did 3dfx patent this feature or something?
Didn't table fog come up in DX5 (circa 1997?). Isn't 1997-2001 (DX8))period a small enough period to consider it a permanent feature, also considering earlier cheap cards would most likely cut out on such features?
BEEN_Nath_58 wrote on 2025-01-05, 22:26:Didn't table fog come up in DX5 (circa 1997?). Isn't 1997-2001 (DX8))period a small enough period to consider it a permanent feature, also considering earlier cheap cards would most likely cut out on such features?
From what I can tell, in the gaming space, table fog was first introduced in 1996 by the original Voodoo Graphics (Voodoo 1). That card and all later 3DFX products supported it in hardware, while cards from other manufacturers had to emulate it in some way, until the GeForce 1.
The document I linked to was written by an Nvidia engineer, before they acquired 3DFX, so he's only talking about Nvidia cards there.
ATi Rage3 and Rage4 paletted textures with OpenGL possible with GLDirect, RageXL example added.
Very cool. I love the RageXL.
You shouldn't need to do this though. Driver version W98_RXL_4_12_2647.exe from November of 2000 already supports paletted textures.
Does anyone know if there is a ATI Rage XL driver that will run Final Fantasy 7 correctly?
Kahenraz wrote on 2025-01-08, 00:14:Very cool. I love the RageXL.
You shouldn't need to do this though. Driver version W98_RXL_4_12_2647.exe from November of 2000 already first paletted textures.
Yes, you do. ATi Rage3/Rage4 drivers seems have only Direct3D paletted textures and OpenGL does not support this function.
If someone have other results i am more than happy to use it without, but even now i have playable framerates with GLDirect.
I use 2582 driver and Direct3D paletted textures are working out of the box, but no OpenGL, tested with many OpenGL version.
Joseph_Joestar wrote on 2025-01-06, 01:37:From what I can tell, in the gaming space, table fog was first introduced in 1996 by the original Voodoo Graphics (Voodoo 1). That card and all later 3DFX products supported it in hardware, while cards from other manufacturers had to emulate it in some way, until the GeForce 1.
PowerVR's had table fog implemented since at least June 29 1995, so it's no 3dfx supersecret
Phil is currently working on a new video about the the GeForce FX 5500, and he did a bunch of testing with regards to table fog, paletted textures and driver version compatibility. He shared these findings with us:
PhilsComputerLab wrote:[…]
- You can force 45.23 through device manager, the card shows up as unknown, but otherwise works fine
- 45.23 gave me corrupted menus in Colin McRae Rally (CD + latest patch). The game works fine however. Upgrading to 56.64 fixes this issue
- 45.23 wouldn't let me launch Need for Speed: Road Challenge (CD + latest patch). Upgrading to 56.64 fixed this issue.
- System Shock 2 wouldn't work with 56.64 and 53.04. After starting a new game, you see the loading animation, then a black screen with a single DING sound. Using driver 45.23 resolved this issue and the game works fine!
- Expendable doesn't show 640x480 as supported resolution. Not a big deal, it runs fast enough at higher resolutions...
- 45.23 has a toggle option for table fog. The newer drivers do not, but you can access it through PowerStrip.
- The table fog option triggers a warning message in Star Wars: Shadows of the Empire. Fascinating. I've never seen it on any graphics card that does NOT support table fog, so that was interesting.
- The table fog option toggles fog in the Thief 2 demo, but does NOT toggle fog in Need for Speed: Road Challenge (CD + latest patch).
- In recent weeks I had never got working music in Driver and with the GeForce FX I also didn't get 8-bit paletted texture support in Final Fantasy 7 and 8! I used, as always, my automated Windows 98 SE installation. It is Vanilla as it gets, and I then install DirectX 7.0a. Well turns out, installing DirectX 8.2 (the filename shows 8.1) fixes this! I always assumed DirectX 7.0a is the gold standard for Windows 98 SE, but seems not, at least not with the GeForce FX.
It might be the case that certain GPUs work best with certain DirectX versions. For example, the Radeon 9000 didn't offer any 3D capabilities with DirectX 6, but needed at least DirectX 7 for Windows to have 3D graphics support.- I've also seen the blurry text issue when using AA. In Drakan for example. The game does have a texel toggle switch, but it only makes it worse. After I completed the project, I found some discussion about using certain levels of AA and AF to address this, so this is something for the future. Star Wars: Shadows of the Empire also has blurry text.
- AF on the GeForce FX is very nice! I found some cool information on Anandtech and 3DCenter.org. With the GeForce FX Euclidean distance calculation was used, but ATI, as well as GeForce 6 and 7 used the faster weighted Manhattan distance calculation. This all goes over my head, but it has to do with angle dependecies. For example, try a Radeon 8000 series GPU (8500/9000/92xx). Enable 16x AF and try a game that lets you lean, or look up a wall and turn. You will see how the Radeon has AF that really only works on horizontal textures. The GeForce FX does this prefectly, and it was until the GTX 8800 that Nvidia had such nice AF again! Isn't that lovely finding such gems of information?
- The DVI out on these Chinese PCI FX 5500 only works once the driver is loaded. A real bummer. I hope someone figures out a fix, maybe a BIOS mod...
I find his insights about the effect of using older DirectX versions, and the Anisotropic Filtering differences between ATi and Nvidia particularly interesting. Additionally, I wanted to share two issues that I have been looking into personally, but haven't had the time to test thoroughly. Maybe someone else can perform the relevant tests:
1) Paletted Texture support on GeForce cards may depend on the driver version. I don't think it works on drivers below version 12.41, and it gets disabled around version 93.71 (Win2K/XP). Again, I haven't tested this thoroughly, so those driver versions may not be the actual cutoff points, but I thought it might be worth mentioning.
2) Table fog compatibility differs between R200 cards (e.g. Radeon 9250) and R300 cards (e.g. Radeon 9600). I noticed that a few games which lack table fog on R200 cards sometimes (but not always) have it on R300 and R400 cards. And this is without any tweaks, and with using the same Catalyst 6.2 drivers. Maybe ATi improved something in the hardware, or the driver path. Of course, R300 cards and above provide perfect table fog emulation under WinXP as of Catalyst 7.11 and higher.
Looking at the Matrox G200 datasheet, it seems like that card might support paletted textures. Not sure about table fog.
If anyone has a G200 card, feel free to post your findings here. A quick test in Final Fantasy 8 and Star Wars: Shadows of the Empire would determine if these features are supported.
Joseph_Joestar wrote on 2025-04-03, 15:11:[*]AF on the GeForce FX is very nice! I found some cool information on Anandtech and 3DCenter.org. With the GeForce FX Euclidean distance calculation was used, but ATI, as well as GeForce 6 and 7 used the faster weighted Manhattan distance calculation. This all goes over my head, but it has to do with angle dependecies. For example, try a Radeon 8000 series GPU (8500/9000/92xx). Enable 16x AF and try a game that lets you lean, or look up a wall and turn. You will see how the Radeon has AF that really only works on horizontal textures. The GeForce FX does this prefectly, and it was until the GTX 8800 that Nvidia had such nice AF again! Isn't that lovely finding such gems of information?
Wasn't GeForce 4ti AF completely non angle dependent, Just brute force.
Dothan Burger wrote on 2025-05-10, 18:26:Wasn't GeForce 4ti AF completely non angle dependent, Just brute force.
I think that's what Phil meant when he wrote that note.
That entire post is from his research, other than the bottom two paragraphs which are mine. I'll edit it to make that clearer.
Where and what kind of fog does Driver 1999 use?
BEEN_Nath_58 wrote on 2025-05-15, 08:02:Where and what kind of fog does Driver 1999 use?
Does it have fog? It has paletted textures for sure.
marxveix wrote on 2025-05-15, 09:43:BEEN_Nath_58 wrote on 2025-05-15, 08:02:Where and what kind of fog does Driver 1999 use?
The graphics settings has a Fog option
BEEN_Nath_58 wrote on 2025-05-15, 10:08:marxveix wrote on 2025-05-15, 09:43:BEEN_Nath_58 wrote on 2025-05-15, 08:02:Where and what kind of fog does Driver 1999 use?
I have seen rain, but no fog, maybe its because i have used ATi cards Rage Pro and Rage128 Pro.
I see only resolutions + use 8bit textures support and use triple buffer option.
