Reply 600 of 1031, by PC@LIVE
- Oldbie
I briefly return to the burnt pins (fused plastic), of the Gigabyte GA-7VAXP ATX connecter, noting that there are four, I checked which lines have four pins (out of the total of twenty), and I discovered that it is +5V, basically it should not be a surprise 😱, the S.462 from what I know, requires a lot of current on that line, and in some cases it exceeds 15A, maybe 🤔 the burning is due to a poor ATX power supply, at least this is what I can imagine 💭.
Fortunately, I have old ATX power supplies, with a sufficient amperage on +5V, recent ones are quite enough only if of high power, since from the P4 we began to use the +12V with many amperes, so nothing strange if an old 300W power supply has more amperes on the +5V, than a new power supply of about 500W.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
