Suntac 80286 Mainboards
Reply 62 of 295, by Predator99
Predator99 wrote:
2019-1-26 @ 11:35 Did not manage to fix it so far... […]
2019-1-26 @ 11:35
But next one:
After some cleaning it looks better:
Seems to be alive, but the delay line in the bottom left is loose, almost all pins broken. Need a replacement...
BIOS:
286-Suntac-A2125580.rar
I now replaced the damaged delay line with a socket and put a modified SN74LS14N on it.
Re: Delay line modern replacement?
With empty delay line socket the board is dead with display "--" on the POST card.
With the SN74LS14N it powers up. But there seems to be still a problem with the RAM. Supersoft dispays garbage CMOS data (not critical I think) and RAM failing bits 0,1,3,7. To my surprise I can exchange the RAMs in any way, its always the same scheme. I also removed all RAMs and still get the same result. The ICs are known working in the other Suntac-Board...
The attachment DSC_8497.JPG is no longer available
Reply 63 of 295, by Deunan
A problem with RAM that doesn't change when moving chips around would suggest the delay line substitution isn't working properly. I still think a HCT chip would do a better job than LS.
Reply 64 of 295, by Predator99
Yes, I am afraid thats a good explanation. I dont like to desolder a working delay line to verify. Therefore I will try with 74HCT14...
Reply 65 of 295, by Predator99
Hmm, did a better wiring job with the HCT but unfortunately still the same result...think I need to test with a known working delay line to be sure its the reason for the fault...
Reply 66 of 295, by Deunan
Please check which pins of the socket are actually connected to the chips. Original IBM 5150 has connections to: in, 20ns, 60ns and 100ns. 40 and 80 are unsused, and the delay line in general has different pinout.
Your replacement will only work on pins 12, 10 and 8, which correspond to 1, 3 and out on the original. 2 and 4 cannot be used as you have these signals inverted. HCT14 has propagation delay of about 20ns so you have 40ns, 80ns and 120ns taps. Maybe that's too slow but that depends on the actual delay line originally used (not all have 20ns per tap).
EDIT: According to Suntac schematics you need 30ns and 60ns delays, and that is pins 12 and 4 (and in on 1). Rewire your chip like this:
1 - in
2 -> 13
12 -> 11
10 -> 3
See if that works.
Reply 67 of 295, by Predator99
Yes, original is the ESAN 31A-5101. It has 100 ns total and 20 ns per TAP. Pinout is on the bottom right of the datasheet at the top the other thread:
Connected on the mainboard seem to be Pins
1, 4, 8, 12, 14
The attachment dl.jpg is no longer available
(bottom view mirrored)
Will try the rewiring later....THANKS!
Reply 68 of 295, by Predator99
OK, almost there with wiring
1 - in
2 -> 13
12 -> 11
10 -> 3
Maybe it was just by chance as its not very reproducable. Did this with loose wires and will solder on the weekend.
But there seems to be another issue. Keyboard does not work and NumLock LED is very dark. At least one jumper needs to be set there, too. Maybe also some corrosion damage left, will check this after the memory being running reliable... UPDATE: Keyboard running, was not tight enough in the socket... 🤣
The attachment IMG_9720r.jpg is no longer available
The attachment IMG_9724r.jpg is no longer available
Reply 69 of 295, by Predator99
OK made a better soldering work on the 74LS14: This cabling works perfectly on every reboot!
Summarized:
- board appears to be totally dead with broken delay line
- 74LS14 is a good replacement but need to consider the required connectors on a case by case basis
- Deunan is the best, many thanks for helping me fixing my 2nd board!!!
The attachment stls14.jpg is no longer available
Reply 70 of 295, by MMaximus
So this means you fixed it? Congratulations guys! 😎
In the mean time I've managed to get a working post card (ordered a cheap one from China but it didn't work so I got a slightly more expensive one from Europe on Ebay)
I'm trying to diagnose the problem on one of my Suntac boards with my very limited knowledge of electronics. It's this board:
It's pictured here with no RAM, but I've tried with different combinations of RAM chips known to work in other boards and still no luck. I've also covered the BIOS chip with a sticker (believe it or not I didn't know about UV erasable chips when I took the photo), and replaced the BIOS chips with one from a working mobo so it's not this either.
The board powers up, but gives no display signal, nothing happens. The diag board doesn't give any diagnostic code either.
Could it be the CPU? I would swap it to check but I don't have my PLCC extractor at hand at the moment.
Hard Disk Sounds
Reply 71 of 295, by Deunan
Connect reset switch. Does the RESET LED on the test card light up when you press it? Also, if you're using a modern 400W+ ATX PSU through an adapter, take note of this LED behaviour when you cut power to the PSU. There should be a brief moment when the LED lights up before the power runs out in the capacitors and the mobo goes dark.
Reply 72 of 295, by MMaximus
I'm actually using an old AT PSU from a working system. I've used a nail to short the JP6 (reset) jumper on the board - and the LED on the test card lights up as long as I short this jumper. I assume it's a good sign? The "IRDY" LED on the test card stays off no matter what, but the other LEDs are on.
Also, I don't know what the JP2 jumper on the test card is for. The card came with some wire to connect this JP2 jumper somewhere. There's also a button on the test card which I don't know the use of. The user manual is in english but probably badly translated from Chinese like many products of this kind, and doesn't seem to make much sense. 😕
Hard Disk Sounds
Reply 73 of 295, by Deksor
Hey I think I have this exact same board in my 286 !
What's odd though is that I can't see any RTC on your board ...
Mine uses a DALLAS rtc chip, but I don't see it on yours either it's actually not the same board, or they used a different way, or it's missing on yours (I haven't opened my 286 since some time now so I don't exactly know where it is, I'll try to check that a bit later)
Reply 74 of 295, by Deunan
I asked about ATX power supply beacuse pretty much all decent ones are 450W+ so the effect with the LED is easy to spot. But you can try that with AT PSU as well, though the results might not be conclusive. The reset switch works as it should on your mobo and so the problem doesn't seem to be reset related.
BTW the JP2 and cable for the test card are to connect the buzzer on it in place of PC speaker. You can verify that by testing connection between those two on the card. No idea what the button is for, I've never used it.
Well it could be the BIOS got corrupted. Not by UV light, unless you kept the board out in the direct sun without the EPROM windows covered. Fluorescent light doesn't really erase these unless it's years of exposure. Or lamps used to kill germs. EPROMs sometimes just flip back to "1" - it's a natural process that takes years even for weak cells but it happens. The mobo should output some error codes even without RAM, so long the CPU works and the chipset is not completly dead.
Do you have something to dump the EPROMs? Or maybe another board to try swapping both?
This mobo uses Motorola RTC, MC14618A - a very common chip. I'm actually surprised there were any Suntac 286 with Dallas chips. Must've been pretty late models.
Reply 75 of 295, by Deksor
Mine is from 1989. I was really happy to discover that as this meant I didn't need to worry about corrosion :DI can dump my bios if needed, mine must be from the same manufacturer because it's nearly identical (I think I've spotted battery terminals on his, so that's not exactly the same, but other than this it's the same if I remember my board correctly).
Edit : here are some photos ! https://imgur.com/a/yqGc4zE
Sorry for view angle on some of them, I didn't want to bother it, it's been sleeping for few months and I wouldn't like to see it unhappy next time I power it on ^^
On image nº2 you can see the Dallas chip with the cr2032 mod behind the mfm cables
Reply 76 of 295, by Predator99
Yes, jumper is for speaker connection. Button is for switching back to the previous code displayed.
Deksor wrote:
Mine is from 1989. I was really happy to discover that as this meant I didn't need to worry about corrosion :DI can dump my bios […]
Yes, can you dump your BIOS please? You can do that with NSSI without removing chips. Does it run with 16 MHz..?
Reply 78 of 295, by Predator99
Yes, crystal seems to be 24 MHz so CPU seems to be running at 12MHz. But its labeled as 8/10/12/16 so it might be possible to oberclock? Never tried...
For RAM upgrade I woiuld recommend a EMS/XMS card like this one 😉
Re: Bocaram AT XMS/EMS memory card replica?
At least you can use the chaeper 41256 for further upgrade and dont need to buy 411000.
I upload you photo of your DATAMINI board gain, dont think imgur is reliable for the future...
Reply 79 of 295, by Deksor
Yeah I know EMS/XMS cards, but I'd rather have that onboard (and the ones I can find are about the same price as the chips I need anyways 🤣)
DATAMINI is the brand of the computer, but I think this is a rebranded motherboard of some kind. I can even bring the BIOS setup disk image 😀
As for the bios itself, I can simply dump it using my TL866 😁
Reply 80 of 295, by MMaximus
Deunan wrote:
I asked about ATX power supply beacuse pretty much all decent ones are 450W+ so the effect with the LED is easy to spot. But you […]
Thanks for all this useful info. I swapped the EPROMs with ones from a working board and the board still doesn't work - whereas the working board works with the EPROMs from the defective board so we can probably rule this out. I'm waiting for a cheap PLCC extractor I've ordered to arrive and then I'll swap CPUs and see if it's the problem.
They look very similar but my boards had barrel batteries that I've removed. I'm now using external battery packs, it works really well.
I had 5 identical boards in total: I put one in a system that I sold, gave one of the non-working ones to Predator99, and now I have 2 functional boards and 1 defective left. I'll see what I can do with the non-working one but if I can't repair it I'll gladly give it away to someone who would want to have a go at it. 😎
Thanks for the info!
I'd be interested to see if the BIOS from Deksor's board is a different one: the one on mine and Predator's is Phoenix 3.10.22. Deksor, does your BIOS offer you the option of user-type HDD?
Actually I was thinking the same thing about 16Mhz... would our boards work at 16Mhz if we swapped the CPU and the crystal? Predator let me know if you try this 😀
Deksor wrote:
No the CPU is 12MHz on mine. Actually I wish I had ram chips to upgrade to 4MB, but I'm stuck to 1MB unless I pay 60€ of ram chips.
I didn't know 411000s were so expensive! 😲 All the boards I had came each with one bank of 411000s to give 2M RAM, so with both banks full it gives a total of 4M.
Hard Disk Sounds
Reply 81 of 295, by Deksor
BIOS dumped ! (I don't know which one is the high chip and which one is the low chip, so I took note of what sticker is on it compared to the photo.)
The attachment Datamini_bios.zip is no longer available
Type 47 is just another preset drive unfortunately.
Also, I've discovered something else. I had an intuition of something, so I removed the controller card just to look underneath the mfm/floppy cables, and guess what I've seen ? Unpopulated battery spot ! So now I'm almost 100% MMaxmimus has the same board as me, just that instead of the MC146818AP chip, there's a DALLAS battery RTC chip.
I've also the manuals of that computer, and the motherboard is documented, so I might scan that someday.
