EAX appreciation thread
Reply 620 of 1280, by sharangad
AndreaColombo86 wrote on 2025-08-10, 18:03:
Has anyone tried this with Diablo II? Does it work / does it sound good?
https://forum.median-xl.com/viewtopic.php?t=59898
Don't have Diablo II I'm afraid.
https://patreon.com/Rready
Reply 621 of 1280, by Joseph_Joestar
I did, a few years back. It was ok, you get more precise positional audio and a bit of reverb in appropriate places. There are some occlusion effects too.
See this post by @Sombrero for more info.
My retro stuff
Reply 622 of 1280, by AndreaColombo86
Anybody tried EAX 5.0 in Mass Effect? Is it good?
Reply 623 of 1280, by sharangad
AndreaColombo86 wrote on 2025-08-11, 15:37:
Only g0t an Audigy RX and a possibly dead Extreme Music (PCI, might work in my retro machine). I no longer have my PCI-E Fatality Pro gamer with 64 MB of XRAM. Can't test EAX5 at the moment. Someone else will have to do it.
Reply 624 of 1280, by nd22
In games that do not support EAX such as Age of empires 2, does a Creative card - audigy 2zs for example - helps or is useless?
Reply 625 of 1280, by AndreaColombo86
nd22 wrote on 2025-08-11, 18:13:
Without EAX support, that’s just another sound card. You’d probably get better sound quality from a modern external DAC.
Reply 626 of 1280, by Joseph_Joestar
Back in the day, Creative had some presets for older games that didn't support EAX. I haven't tested that thoroughly, but I remember that there was one such preset for Diablo 1, as an example.
That said, I think (not sure) that these presets were only included when using SBLive cards with their original drivers.
My retro stuff
Reply 627 of 1280, by chinny22
Joseph_Joestar wrote on 2025-08-11, 18:53:
I remember using those presets back in the day, I'd also apply the same pre-set with similar games, eg if Red Alert had a preset I'd apply that to any RTS's that didn't have a preset.
I think you can still make profiles. But I haven't done any of this for years though.
Even leaving things at default as I do now an Audigy sounds better then basic onboard AC97 audio, especially if you enable say CMMS. Which is why I still tend to put them in every build.
EAX support for games that have it, and decent sound card for games that don't. It's still a Win/Win
Reply 628 of 1280, by nd22
I know about Diablo 1 preset and I use it in my Pentium 2 system where I have a Live card.
Recently I finished testing socket A and I kept my favorite system assembled: XP 3200 with geforce 7600gt on Abit AN7. I wanted something more than sound storm so I installed an Audigy 2ZS which has EAX 4.0 so is more than enough for the time period this PC covers. I specifically did not installed a Live card because I think that sound storm and Live are very similar: both have EAX 2.0 support so it would not constitute an upgrade.
I am going to try Live to see if indeed Diablo 1 sounds better than on sound storm.
Reply 629 of 1280, by AndreaColombo86
I’ve just tried Baldur’s Gate 2 on my Sound Blaster Live! using the 2004 driver for Windows XP. I can confirm that the occlusion effect is present.
However, I could not hear it in the Temple of Lathander, the one with the spinning 3D orb that makes a noise. No matter where in the viewport the sphere was, I could not hear a difference between Environmental Audio turned on or off.
Reply 630 of 1280, by Joseph_Joestar
AndreaColombo86 wrote on 2025-08-13, 16:51:
I only briefly tested occlusion in Baldur's Gate 2 with SBLive + WDM drivers, so I can't say for sure how well that works across the entire game. For best results, I recommend playing it on a Win9x rig using VxD drivers. Back in the day, VxD was the norm for gaming, so the developers likely targeted that while testing EAX.
By the way, if you're using a 5.1 speaker setup for EAX under Win9x, you need an Audigy. I gave up on SBLive cards because they always have CMSS turned on (hardcoded), which messes up positional audio on surround speakers. With Audigy cards, you can turn CMSS off at your leisure.
My retro stuff
Reply 631 of 1280, by KainXVIII
UCyborg wrote on 2025-07-09, 19:22:
For one thing, started playing through Max Payne 1 again recently, I did like the punch CMSS added to bomb explosion underground in one of the first levels. It's not something that can be normally reproduced in other ways without bumping up the volume, which make other things sound unnatural to me.
Talking about MP1, what did EAX adds to this game? Can't hear any difference in reverb and such effects, maybe it only gives better surround sound?
Reply 632 of 1280, by Joseph_Joestar
KainXVIII wrote on 2025-08-18, 21:49:
From my brief testing a few years back, I think Max Payne 1 only uses DirectSound3D. At least I found no references to EAX when I checked the game's documentation and executable. Even so, DS3D will give you some very nice positional audio.
That said, the sequel (Max Payne 2) does use EAX 3.0. From memory, I think I encountered both occlusion and reverb effects while plying that game.
My retro stuff
Reply 633 of 1280, by KainXVIII
Joseph_Joestar wrote on 2025-08-18, 21:57:
That explains why there are no checkboxs on vogons wiki! (or maybe somebody need to remove MP1 from this wiki to not confuse the future users 🤣)
The attachment Снимок экрана 2025-08-19 104425.png is no longer available
Reply 634 of 1280, by Joseph_Joestar
KainXVIII wrote on 2025-08-19, 07:45:
Yeah, we inherited a lot of games without any checkboxes from the original list on Wikipedia. When that was compiled, one of the sources was apparently Creative's ALchemy page. But in my view, that's not always accurate, since ALchemy also supports some DirectSound3D games, and not just EAX titles. That's probably what confused the people who added the original entry.
I could clean this up, but I haven't tested every single game without checkboxes on the list, so I'm a bit hesitant to remove potentially valid but unvetted titles. Might be better to just write "DirectSound only" in the notes section for Max Payne 1. Not sure.
My retro stuff
Reply 635 of 1280, by AndreaColombo86
What do the audio options say in Max Payne 1? Do they even mention EAX?
Reply 636 of 1280, by KainXVIII
AndreaColombo86 wrote on 2025-08-22, 21:39:
Nothing in options mentions EAX, maybe something in a readme file which i don't have (i own only Steam version)
Reply 637 of 1280, by Joseph_Joestar
KainXVIII wrote on 2025-08-22, 21:56:
I have the original CD version of Max Payne 1. There's no mention of EAX in the readme either.
My retro stuff
Reply 638 of 1280, by willow
in max payne 1 manual and box, only directsound sound card support is displayed, not eax support
