Reply 640 of 642, by MalekBrood
myne wrote on Today, 00:17:Been Nath is the dxwnd expert who got them all working. You're in the right track though. It's some dxwnd setting. […]
You're in the right track though. It's some dxwnd setting.Reaching Khan =gbl?
The trick to that is to NEVER die in the entire game.
I've not played GBL yet, it's the base MW2 I'm on about. In the DOS version when you start either Jade Falcon or Wolf you should start as rank Mechwarrior (I'm not sure if you have to complete the training trial or not to get promoted to Mechwarrior) then after completing both phases of the first trial you gain two ranks which should make you a Nova Commander, but for some reason in the Titanium Edition you start has a Cadet (completing the training trial doesn't get you promoted to Mechwarrior), so after completing the trial you can only gain the rank of Star Commander, one behind Nova Commander because the phase one promotion takes you from Cadet to Mechwarrior then phase two promotes you to Star Commander. It is a known bug apparently, when I realised what was happening I did some googling and found an old post from years ago talking about it. Here's what I found https://www.mech2.org/forum/viewtopic.php?t=1064
