DOSBox-X branch
Reply 700 of 2421, by kolano
I do wish we had a more identical render path for OpenGL as Direct3d. I know most of the advancements there are unsupported patches, but it's frustrating to not be able to provide similar cross platform compatibility with DOSBox configs between the two.
Eyecandy: Turn your computer into an expensive lava lamp.
Reply 701 of 2421, by leileilol
I think I keep plugging this thread now and then. It did try to exist.
long live PCem
Reply 702 of 2421, by arromdee3
Forced does fix my problem, and it also does work in combination with output=opengl, so it's actually as fixed as I could expect now (as long as I patch out that +80 EF2000 code). Thanks.
(Forced plus fullscreen plus a scaling method that is too big for the screen will result in a segfault, however.)
Reply 703 of 2421, by truth_deleted
That's good news. We also documented the problem where Ykhwong's build works as expected, so someone could construct a diff file between the two builds, perhaps using an older version of dosbox-x, and look for code related to SDL video and the like. The relevant commits shouldn't be too many to isolate the cause.
Reply 704 of 2421, by truth_deleted
Attached difference file to document the above issue with scaling. It shows that the opengl output mode is unavailable, so that is a probable reason why full screen scaling is unavailable. If the opengl mode code was introduced, then it should be possible to scale full screen. As it is, the output mode is necessarily reverting to surface. Although surface should also scale to full screen, I've confirmed that opengl mode is expected to work where surface is not (in a private dosbox build; this does not refer to vanilla dosbox).
Also, confirmed that dosbox-x uses a new text mode which stretches the horizontal width of the screen beyond the default width (640). So, where using the scalers such as normal2x, the window will stretch beyond 1280 pixels in width. If the default dosbox text mode was used, then the 2x scaling should fit within the screen space of a 1280H monitor and not generate an error while switching to full screen with a scaler active.
I would first add the opengl mode and test full screen scaling, if there is any issue, then revert back to the default text mode of dosbox. 😀 Otherwise, the window scaling (non-fullscreen) works with the "forced" parameter, so this is a simple workaround.
Edit: removed attached diff file and replaced it with a patch attached to the next post in this thread.
Reply 705 of 2421, by truth_deleted
Patch is attached to reactivate opengl mode along with window and full screen scaling. Requires testing in other systems since I only tested it in a build by mingw/gcc.
The patch may contain parts which do not apply cleanly to the latest dosbox-x, so these parts would be applied manually.
Reply 706 of 2421, by exofreeze
Using this branch I was successful in installing Win 3.x to an image, booting the image, and accessing the mounted cd image. However I have not been able to do this with Win95.
In Win 3.x, apart from adding the ide sections to the conf file and mounting the image, I also had to define the driver file in the config.sys file and then call mscdex to detect the drive.
Since Win95 does not use an autoexec.bat and config.sys, I can't really use that step... yet Win95 doesn't seem to detect it on it's own.
Considering the number of resources I have found online that suggest this should be as easy as using the X Branch and properly setting up the conf file, I am having difficulty figuring out what I have missed her.
Would someone mind assisting me? Thanks.
Reply 707 of 2421, by SedrynTyros
Actually, Windows 95 uses both config.sys and autoexec.bat during boot time.
Reply 708 of 2421, by DosFreak
I haven't tried Windows 9x in DOSBox-x but the way Windows 9x has always worked is you can load the CDROM driver in DOS and then load Windows and Windows will use that driver or you can switch Windows to use the Windows CDROM driver.
Make your games work offline
Reply 709 of 2421, by exofreeze
wow.. I popped open the disk image and didn't see a config or autoexec, so I assumed it didn't use them.
DosFreak - the image boots directly in w95. I'm not sure how it is possible to boot to dos first and then start up win95. Maybe you mean by hitting f8 during boot and redirecting to the dos prompt?
I went and stuck a config.sys with one line in it that loads the my cdrom driver, and then I added an autoexec batch that called mscde, and that worked perfectly. Now it passes my mounted cd image right over to windows.
Whats odd, is I saw the same steps on multiple websites on how to use the x branch to do this, yet none of them mentioned adding these files. Thanks for the help.
Reply 710 of 2421, by DosFreak
Windows 9x uses DOS as a loader so DOS will always load first you just won't see it. 😀
http://blogs.msdn.com/b/oldnewthing/archive/2 … 24/6849530.aspx
You can also use the shift key but that can be confusing when using a VM and also the VM may load too fast.
This would be easier:
http://www.computerhope.com/msdossys.htm
BootGUI
I want to say that unless you had DOS previously installed then autoexec.bat and config.sys will not be there.
What's really annoying is that for the longest time Windows NT4+ would always create zero by config.sys and autoexec.bat files in C:\ even if you didn't have a dual-boot. grrrr
Note that even if config.sys does not exist Windows will load some drivers that would have been in there:
http://support.microsoft.com/kb/174018
Reply 711 of 2421, by gulikoza
That's one way, but actually what you should do is run add new hardware wizard and install the IDE controler. That way, the CD-ROM drive will be connected natively and not through DOS MSCDEX calls.
http://www.si-gamer.net/gulikoza
Reply 712 of 2421, by SA1988
thanks for the partial FDC emulation! However, I cannot switch floppies by using the imgmount command with "boot -l a" specified.
Reply 713 of 2421, by TheGreatCodeholio
Don't thank me yet, FDC emulation is still under development! 😀
Are you specifying more than one disk image with imgmount?
DOSBox-X project: more emulation better accuracy.
DOSLIB and DOSLIB2: Learn how to tinker and hack hardware and software from DOS.
Reply 714 of 2421, by SA1988
yes, I mean that in boot mode.
Reply 715 of 2421, by truth_deleted
Try verifying the same behavior in vanilla dosbox.
Reply 716 of 2421, by SA1988
same thing happens.
Reply 717 of 2421, by TheGreatCodeholio
SA1988 wrote:
same thing happens.
I recall that DOSBox has never really supported the multiple disk swapping mode unless "boot" is used directly with multiple disk image files, or if multiple .iso images are given when mounting a CD.
You should be able to do multiple floppies with disk swapping if you do something like:
boot "disk1.img" "disk2.img" "disk3.img" "disk4.img"
Reply 718 of 2421, by SA1988
that works fine but I mean, for the future fdc uses, it is implemented (although preliminary) in the imgmount one.
Reply 719 of 2421, by dosquest
Any more builds to test? 😁
Doom isn't just a game, it's an apocalypse survival simulator.
