Reply 700 of 860, by Mr.Hunt
@JazeFox, I have a problem with switch on MIC In at sound card on crystal CS4232. At Windows we can switch on mic, but on dos not. Is it possible something to add to unisound for activation this function ?
Reply 701 of 860, by Nemo1985
Mr.Hunt wrote on 2025-03-26, 09:40:
JazeFox hasn't answered for a long time, maybe something happened?
He did gone missing for some time in the past too, he also mentioned to be busy so I see nothing worring about it.
Reply 702 of 860, by pan069
I think this has been suggested before, but it would be really nice if Unisound were to become an open-source project. I can totally understand that JazeFox wouldn't want to deal with that but he could appoint maybe two other maintainers (people he'd trust) to help manage it with/for him. I am sure there are credible (and capable) people in the community who'd volunteer for that.
Reply 703 of 860, by 640K!enough
pan069 wrote on 2025-03-26, 19:48:
It has been suggested before, and he has firmly rejected the idea on multiple occasions, most recently promising that that was one of the repeated requests that he would ignore going forward. He can certainly change his mind, but he made it sound like that was rather unlikely.
Reply 704 of 860, by pan069
640K!enough wrote on 2025-03-28, 19:37:
It's a real shame because its getting to point that there is a need for a community alternative that isn't under the control of one person who disappears for extended periods of time.
Reply 705 of 860, by Boohyaka
pan069 wrote on 2025-03-28, 20:47:
No, absolutely not. That person wrote some piece of software and they are under no obligation of any kind to make it open source, and the alternative is in no way that they need to be available at all times on a public forum. That sounds very entitled, and way too common in the current software landscape. Would it be better, or easier if it was open source? Yes, not arguing that. But in the end it's their prerogative. They don't own anything to anyone.
If there's such a "need" as you say, the "community" will eventually write an open-source alternative.
Reply 706 of 860, by Nemo1985
Also I would say about a "similar" utility, SBEMU, it is open source, the developer has the habit to go missing, guess what? Noone else take care of it, there are bugs waiting to be solved since the developer stopped work on it, so the open source is not the assured solution for everything.
Reply 707 of 860, by ]--Freeman--[
Hi! I am using Unisound with my SB Awe 64 and it works like a charm!! But I have a problem with games that only need a BLASTER environtment with 4 parameters like Hocus Pocus or Duke Nukem 2. If I change de BLASTER to set only 4 parameters (A220 I7 D1 T4 for example), unisound converts the BLASTER variable in the format it needs with the parameters that I've not defined like P330 or E620 with its default value. Is there a way to short it and works Unisound?? Thanks!!!
Reply 708 of 860, by Pickle
]--Freeman--[ wrote on 2025-04-01, 10:50:
Did you try doing two set commands one before the unisound call and then after in the autoexec?
You might also create a batch file for those games and do the set blaster in it
Reply 709 of 860, by ]--Freeman--[
Pickle wrote on 2025-04-01, 12:57:
What do you mean? Something like that?:
In autoexec.bat:
SET BLASTER1 = A220 I7 D1 H5 P330 E620 T6
SET BLASTER2 = A220 I7 D1 T4
UNISOUND BLASTER2 /V99
or in a batch:
@ECHO OFF
UNISOUND /D
SET BLASTER = A220 I7 D1 T4
UNISOUND /V99
HOCUS.EXE
UNISOUND /D
SET BLASTER = I7 D1 H5 P330 E620 T6
UNISOUND /V99
Reply 710 of 860, by vico
Create a HOCUS.BAT file in the game folder containing the following:
@ECHO OFF
SET BLAST=%BLASTER%
SET BLASTER=A220 I5 D1 H5 P330 T6
HOCUS.EXE
SET BLASTER=%BLAST%
SET BLAST=
You can then run the game from this .bat file.
BLASTER values ​​may vary; don't forget to change them to your correct values.
Reply 711 of 860, by analog_programmer
vico wrote on 2025-04-01, 14:42:
Create a HOCUS.BAT file in the game folder containing the following: […]
@ECHO OFF
SET BLASTER=%BLASTER%
HOCUS.EXE
SET BLASTER=%BLAST%
SET BLAST=
@ECHO OFF
SET BLAST=%BLASTER%
SET BLASTER=A220 I7 D1 T4
HOCUS.EXE
SET BLASTER=%BLAST%
SET BLAST=
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 712 of 860, by vico
analog_programmer wrote on 2025-04-01, 14:51:
@ECHO OFF
HOCUS.EXE
SET BLASTER=%BLAST%
SET BLAST=
@ECHO OFF
SET BLAST=%BLASTER%
HOCUS.EXE
SET BLASTER=%BLAST%
SET BLAST=
Actually the game doesn't work when it finds E620 or other strange value in the BLASTER variable.
Reply 713 of 860, by analog_programmer
vico wrote on 2025-04-01, 15:03:
Actually the error with variables setting was in the second row of the batch file. I don't know which BLASTER values will work with this game.
Reply 714 of 860, by ]--Freeman--[
It doesn't work. I've made it step by step but after the blaster variable has the same parameters when I type unisound /R. When I run Hocus it has the same error:
Invalid parameter in Blaster Environment variable.
I don't why I can't change the blaster variable. It happens the same with creative driver.
Reply 715 of 860, by bttr
]--Freeman--[ wrote on 2025-04-01, 18:02:
If several files with the same name but different endings are found in the same folder, the priority decides: COM before EXE, EXE before BAT
So, if you just type in "hocus" at the DOS prompt, DOS will run HOCUS.EXE not HOCUS.BAT. Name your batch file GOHOCUS.BAT instead.
Reply 716 of 860, by ]--Freeman--[
bttr wrote on 2025-04-01, 18:10:
That's a good point to know it!
I've tried with this change but same results.
If I set only the music with soundblaster and sound fx with nothing, the game runs but only music. Sound fx is pc speaker. There is something related with the size variable but I don't know. 🙁
Reply 717 of 860, by vico
]--Freeman--[ wrote on 2025-04-01, 18:19:
That's a good point to know it! […]
Maybe this will help you
https://retrosystemsrevival.blogspot.com/2019 … ter-setter.html
Reply 718 of 860, by ]--Freeman--[
vico wrote on 2025-04-02, 16:32:
Thanks, Vico! I'll try but I don't have much hope. 🙁
I'm dissapointed with the Awe64. I expected more compatibility with early games.
Reply 719 of 860, by vico
]--Freeman--[ wrote on 2025-04-04, 13:05:
I have an awe64 and I can play Hocus Pocus with both Unisound and the Creative drivers.
