Reply 720 of 1395, by feipoa
- l33t++
Sphere:
galanopu's interposer isn't built yet. A common tactic used in marketing is to advertise before its available in order to build anticipation. Yes, I think everyone would like to see how the performance of a board from a "professional PCB designer" stands up to our rag-shag model.
Yes, we should bring back the Cout and Cin pads to the centre, but make them for size 1210.
I think no need to make Cin1 2312 and 1210 compatible. Even the MIC had a slightly better output with ceramic placed there. Just make it 1210, or if you need more space 1206. But if you make it 1206, then assembler will be using two different caps for centre region and Cin1, thus this is why I picked 1210. you see 1206 in my images because that is all I had on hand. Also, shrinking Cin1 to 1210 may give you the extra clearance you need for that little stop near the trimmer.
I think looking at the back side of the trimmer would be hideous. I wouldn't flip it at any cost. If wanting to save space further, perhaps we can use a smaller tantalum at Cout? However, ESR will probably increase and I don't know how LP will perform in that case.
If at all possible, it might be best if you swapped the location of the R1 + R2 combination with that of the header. Normally you want the voltage set circuit near Vout, but here we have that part of the circuit on the other side of the the board. Not a big deal if it cannot be flipped because I've already tested it and it is functional as is.
Were you able to implement those PGA solder pads like rasz_pl suggested?
I'm not sure how wide the PCB is at present, but the width of the slim PGA-168 sockets I am using is 1.700". I wouldn't go less than that - not enough PCB real-estate securing the through-holes.
