Reply 740 of 1372, by feipoa
- l33t++
I only suggested that you edit your 'store' comment. If you do not want to edit your comment, perhaps because you feel it was an attack on your authority, character, or whatever, so let it be. I feel that I have done my job in pointing it out, and that not doing so could imply agreement by complacency. Based on the comments from others thus far, I do not feel I am alone in my original observation. I've also had a private message confirming my original thought, stating that galanopu's comment seemed rather 'slimy' and out of place.
Nobody is or was intending to attack your character or sense of self worth; it is pretty clear based on the point-by-point tries at vindication that this is how you have taken the comment. If I see something out of place in the context of the forum's dialogue, which I felt your 'store' comment was, I will point it out. I firmly believe that your post was an innuendo for advertising your website and was placed in poor taste with the rest of the thread. I have always been in strong agreement with the forum rules that any form of advertising is banned, however there seems to be some quiet acceptance of open sourced projects, or projects originating from the forum.
I've tried my best to formulate my sentences in the least combative approach while still conveying the intended message, and if I have failed in this regard, I apoligise. If there has been any misunderstanding, I deeply apologise for that disruption as well.
Now that you have tested your unit, please feel free to share your Vin and Vout noise levels with a 100 mV voltage scale and 100 us time scale. For a closer comparison, could you run the SXL at 40 MHz in 1x mode, sitting at the DOS prompt (not at or before POST, nor while booting), and with the cyrix.exe flags, -e -i1 -f -r and -m- but not -cd. This will provide a more telling comparison.
I say 1x/40 MHz only, because after clock doubling, noise gets cleaned up a smidge. From the three SXL2-66 chips I have tested, they would run OK at 66 MHz and 3.3 V on the replica interposer that sphere has so generously worked on for the past few months. I did not try lower voltages. 75 MHz needs 3.6 V. You will want to, at minimum, let Quake run in look for an hour, and ensure doom completes. I let Quake run for 3 hours because I walked away and forgot about it.
80 MHz gets more interesting and depends on the CPU. I have one which will do 80 Mhz at 3.75 V, while others need 4.0 V. At 90 MHz, going up to 4.6 V still did not help. If you have a device which fits into the DIP-14 machine pin socket on 386 boards, and allows for 1 Mhz increment adjustment in the 80-90 Mhz range, we may be able to further optimise the operating frequency.
Sphere, I recall that I routed the trimmer so that a clockwise turn increases voltage, not decreases it. I have a few motherboards I modded and didn't think carefully about the direction and am always frustrated having to turn counter-clockwise to increase the voltage. I don't recommend swapping the turn direction.
I have tested with 8x caps in the centre and showed it can improve the noise some. Yes, use the 1210 MLCC size. If you just cannot make 8 caps fit, do 4 or 6. I spent some hours playing with combinations yesterday, but kept coming back to my original configuration. But it will not be detrimental to use 4 or 6 centre caps. Yes, make Cin1 1210. if you want more space, 1206, but it is the same length as 1210, just less deep. Alternately, I showed previously that there was some benefit in using 10 uF at the PGA pins, but I did not try removing all the 100 nF caps and replacing them with 10 uF.
Yesterday, I tried one more time with all 21 PGA caps, but system didn't boot and I got a very curious waveform on the scope. Went back to 8 and it was fine.
