Reply 740 of 825, by megatog615
For some reason UNISOUND is setting up my AWE64 with DMA1/HighDMA1 on the first try. Starting BLOOD results in a crash complaining about high DMA being incorrect. Running UNISOUND again after that sets up DMA1/HighDMA5 as expected from my BLASTER variable:
BLASTER=A220 I5 D1 H5 P330
...which is the FreeDOS default.
Reply 741 of 825, by Pickle
megatog615 wrote on 2025-04-30, 01:24:
For some reason UNISOUND is setting up my AWE64 with DMA1/HighDMA1 on the first try. Starting BLOOD results in a crash complaini […]
stupid question but do you have a SET before that in the autoexec.bat?
also i cant remember if it was case when i had freedos running, but maybe there is a SET BLASTER overriding the one you intend to use. Are you just running unisound command or does include the set blaster you intended as well?
maybe as a test make a batch file with the setblaster and unisound and run it once you hit the prompt.
Reply 742 of 825, by vico
I think the BLASTER variables that FreeDOS sets by default are based solely on the most common variables, not on your hardware configuration.
To get the actual values, you should use a tool like ctcmbbs, or you could look them up in the Windows 9x Device Manager if you have it installed.
https://www.philscomputerlab.com/creative-labs-drivers.html
Reply 743 of 825, by megatog615
vico wrote on 2025-04-30, 02:57:
I think the BLASTER variables that FreeDOS sets by default are based solely on the most common variables, not on your hardware c […]
Maybe, but UNISOUND's documentation says that it sets these values from the BLASTER variable, not anything else, from what I can tell.
Pickle wrote on 2025-04-30, 01:56:
Yes, UNISOUND is being loaded after BLASTER is set.
Don't forget that UNISOUND is setting High DMA to 5 after a game loaded. If I run UNISOUND twice in a row it doesn't fix it. Only after Blood crashes does it set correctly.
Reply 744 of 825, by JazeFox
Hi!
It's been a while since the last update! Real life rules.
I'm planning a bugfix and some little improvement release for the next week (soon (tm)).
Now, although a little late, answers to some questions (sorry if not all, but some are already answered in the first post FAQ, that now is required to be read!):
Cryptus wrote:
This driver is really nice!
Just one question, is it possible to implement an errorlevel (for use in batch files), e.g. errorlevel 1 if driver was not loaded (because of wrong option or soundcard not detected) and errorlevel 0 (only) in case of success? (or vice versa)
and...
megatog615 wrote:
I am also wondering if there is any documentation on this. I'm trying to set up a hardware detection batch file and error levels would be fantastic.
Yes! This is implemented in the next version, to be released soon! (tm) 😀
theelf wrote:
Hi, thanks a lot for your great work, i use unisound in almost all my machines, is amazing
I have a question, i tried to use Reverb (/VRnn) and Chorus (/VUnn) option in my AWE64 Gold, but nothing happen, is gold supported? thanks
Yes, it's tested in the AWE64 Gold and it works, but please note that this option only applies to FM sound processing, not wavetable.
Grzyb wrote:
I've found a case where the original init utility works properly, but UNISOUND fails... […]
The sound card is some generic noname based on Opti 82C933.
The OS is Windows 98SE with BootGUI=0.
Again, everything's fine - notably I can hear both FM and PCM, eg. in SkyRoads.
Now, Windows...
Now, let's replace SNDINIT with UNISOUND...
MP3 still plays fine, but... .MID playback fails!
Looks like it's playing, but can't hear anything...
More interesting is the fact that "Adlib" ports got changed as well - after SNDINIT it's 380-38B (strange, but works), after UNISOUND it's 388-393 (looks somewhat normal, but doesn't work)...
Yes, It's interesting because this is a new scenario. Never used Windows 9x after Unisound (because it's not supposed to be used like this), but anyway... I tested, and it seems that OPTi Windows driver needs Adlib part to start at 0x3x0 to work properly. This can be solved with a change I made for the next version, you'll be able to specify an OPL address between 0x300 and 0x3FF (so you will be able to set F380 in BLASTER var). Tested and it works.
Geri wrote:
You have mentioned its freeware, however, can it be bundled with other software (free or commercial games for example as a generic driver)?
Yes! It can be distributed and bundled freely with any program or game. No limitations, no need to ask for permission! I added this to FAQ in the first post and will add the same info on the TXT for the next versions.
Kekkula wrote:
Not a bug but feature... Since unisound is mainly for pnp cards. I use unisound with sound blaster 16 CT2290 card, and noticed t […]
I use unisound with sound blaster 16 CT2290 card, and noticed that unisound doesn't apply SET BLASTER settings. If I configure environment mpu to 300 unisound allways change it to 330. Doesn't matter if the card is jumppered to 300 and set sound has p300 in it.
If I disable mpu by jumper in the card unisound still sets it to p330 even if it's not configured at all in set blaster or is configured p0.
Luckily machine still regonices sound blaster mpu disabled and I can use my picogus as intelligent mode hard mpu card.
Edit: I don't know what changed but now it recognise jumper setting and disables mpu if jumper on the card is set disabled...
But strangely if the jumper is set enabled and address is set @300 unisound still sets mpu to 330.
Well, let's explain why this is working like this in your case: With SB16 Non-PnP cards, there a lot of variants, some of them are fully software configurable and some are half-software and half-jumpered configurable. In any case, when Unisound initializes a Non-PnP SB16, it tries to set the software configurable part, and then it checks the values in the card and it shows them. In your case, as the MPU part is jumpered, Unisound doesn't "set" or "apply" anything there, it only checks if MPU is working at some address and shows the info. But your case is special, because I guess you have the PicoGUS plugged too, with MPU mode activated, so even though you disabled or changed MPU jumper in the SB16, if Unisound check MPU addresses and if it finds one that is working (the first in reverse order), maybe the PicoGUS one, it shows it. Unisound is not able to know if the port is on the PicoGUS or the SB16.
theelf wrote:
Hi guys, im building a P2 machine, zida bx98-3d, awe64 gold […]
Unisound crash in ram detection in first isa slot, and in second just detect 0kb
Official creative driver, ctcm, detect fine and card works good. Aweutil is able to emulate gm, mt32, and no problem to upload 4mb sound bank
any ideas?thanks
EDIT Happen same with gold and value awe64
Hi, this is very very strange. AWE detection is thoroughfully tested in a lot of systems and variants. Please, provide more details (I know I insist a lot on this but it is VERY important), all the machine specs, all cards plugged of any type, OS, Unisound version (should be latest 😉) if it happens in other systems with the same AWE card, a photo or exact reproduction of the entire Unisound output after running, the contents of your CONFIG.SYS and AUTOEXEC.BAT...
I'm interested on this issue, I we're able to reproduce it.
AirIntake wrote:
My IBM Aptiva E2N 2153 has an onboard Crystal CS4235-KQ. It works fine in Windows 98 and DOS using the drivers pv2860.zip from Philscomputerlab.com. It doesn't get detected by Unisound though, giving me the error "Unknown PnP card [CSC8025] found. Aborting...". Any ideas?
Hi, thanks for reporting. Support will be added in the next version. When it arrives, pelase test and report.
ltning wrote:
I'm one of those people who have to automate everything, so I have a bunch of BAT files that take care of sound, networking, mou […]
I'm one of those people who have to automate everything, so I have a bunch of BAT files that take care of sound, networking, mouse, and whichever other drivers I need on any given machine. I'm obviously using UNISOUND for much of this, but there's a tiny thing that is bugging me: There is no "detection only" mode for non-PnP cards.
That's basically what this feature request boils down to: UNISOUND does everything I need it to do. I'm just bugged by the fact that I can't use it to detect - or rather, confirm the existence of - non-PnP cards in the system *without also initing them*.
So in case it was not clear: I love unisound, this is not a flaw. Just me being silly, I guess. 😁
Hi! thank you for your words, as usual 😀
Well, first of all, Non-PnP suppport is EXPERIMENTAL, and as I said other times, anything could happen. And, for now, no new cards or features will be added.
That said, the feature you want is (I think) not possible. The methods needed for some Non-PnP cards to be detected imply some minimal "initialization", so it would be a mess if you to "detect" (and partially initialize a card) and then try to detect another. Ugly things could happen. I prefer to keep it the way it's working now. Also remember, that this Non-PnP feature is intended to be used with only ONE card plugged in the system.
keropi wrote:
Does unisound support the AuxB volume setting for the ESS 1868/1869 chips?
I cannot seem to find any setting for this, am I missing something?
Yes! but it's tied to /VFxx, because all known implementations use this for External wavetable only. Anyway, I see the use case of the MK1869 and this will have a separated option in the next version!
Hi, that behavior is really strange. Just to be sure, I tried to reproduce your settings, but everything worked well:
- Plugged an AWE64
- Formatted HDD
- Installed a clean copy of FreeDOS, last version available in the official site (It sets by default BLASTER=A220 I5 D1 H5 P330)
- Installed BLOOD
- Ran Unisound (It shows the correct setting, H5, it reports BLASTER var found.)
- Ran BLOOD SETUP and set AWE for FX and music, IRQ 5, DMA1 1, DMA2 5, 16 bit mixing.
- Ran BLOOD, it works perfectly.
- Rebooted and repeated all steps with all options, everything worked at the first try.
There must be something in your setup that is different. But you did not provide any details. so please, I will say it again: (I know I insist a lot on this but it is VERY important), provide all the machine specs, all cards plugged of any type, OS version, Unisound version (should be latest 😉) if it happens in other systems with the same AWE card, a photo or exact reproduction of the entire Unisound output after running, the contents of your CONFIG.SYS and AUTOEXEC.BAT... Also show the output of "SET" before and after you do all the steps.
Greetings to all, see you soon!
Before posting, please, read the FAQ in the first post and TXT! IT's important if you want a good support. Thanks!
Respect, and be happy! 😀
Reply 745 of 825, by Linoleum
I had that "problem" once with my AWE64... It was when I was using an "old" SET BLASTER setting from a SB PRO that only had "D1" and no "H#". Unisound then made it D1/H1...
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 747 of 825, by megatog615
Linoleum wrote on 2025-04-30, 19:28:
H5 is definitely being set in BLASTER.
An update, sometimes if I type out unisound manually it will see DMA 5. No idea what's going on, it's seemingly random.
Reply 748 of 825, by JazeFox
Hi!
New release, with some bug fixes for known and reported problems and small additions.
Tool updated to v0.82a
Changelog:
  • Added support for AuxB volume control on ESS 186x cards using /VBxx (00-99). Useful for cards like MK1869 which have onboard Wavetable and also a Wavetable header. If /VBxx is not specified, behaviour is like in previous versions. If /VBxx is specified, /VFxx will control FM volume and onboard Wavetable and /VBxx will control AuxB separately. Example uses with MK1869: /VF00 /VB90 will mute onboard WT and will put external WT board to 90% vol. And /VF80 /VB00 will mute external WT and will put onboard WT to 80% vol.
  • Added support for Rockwell RWA011 cards that remained muted in previous versions (like Zoltrix Radio Max). If detected, they will get unmuted correctly. If your RWA card remains muted, please try with option /XRU
  • Added support for new card variants: ESS Samsung Audio Magic X SAB-3000A, Crystal CS4235 based ID CSC8025 and generic CMI 83xx variants (not tested).
  • Let user change Adlib/OPL/FM port to any port in range 0x300-0x3FF. This will allow, for example, to assign value F380 in BLASTER var to fix the problem with OPTi 931/933 chips not playing adlib sounds when running Win9x after Unisound.
  • Fixed reading OPTi DMA2 different to disabled/4.
  • Fixed CS4232 MIC input control.
  • Added *EXPERIMENTAL* support for Non-PnP OPTi 82C930 based sound cards, configurable resources: Base Address, IRQ, DMA, MPU port, MPU IRQ, Joyport. Use at your own risk.
  • Implemented ERRORLEVEL on exit. 1 = Card not found/Unknown. 0 = OK/Other.
The download link is updated at the end of the first post as usual:
UNISOUND - Universal ISA PnP Sound Card Driver for DOS v0.82a
And please, read the FAQ in the first post and the TXT before posting. Thanks!
Reply 749 of 825, by keropi
Amazing news JazeFox thanks so much for your work on this! 😁
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 750 of 825, by Mr.Hunt
Огонь, брат! Спасибо большое! 👍
Reply 751 of 825, by Jccwu
does the program work with non-pnp cards (non creative), and if so, with what key?
Sound card's music
Reply 752 of 825, by vico
Jccwu wrote on 2025-05-05, 17:54:
Yes, with the /NOPNP option, look at the UNISOUND.TXT file for a list of compatible sound cards
Reply 753 of 825, by moturimi1
JazeFox wrote on 2025-05-05, 07:36:
Hi!
Great to see that you are still involved in this great project of yours.
I would like to know if you plan on improving the detection of the Kurzweil Pinnacle soundcard.
Unfortunately the card I own is not detected.
The card is configured as PNP device.
When I use Unisound.exe without any additional option it is completely unknown by Unisound.
When I try "Unisound.exe /FS" I get the information "unknown PNP card [BVJ0440] found. Aborting."
The main issue I have with the original init tool is that the mixer settings are off. When I want to use wavetable under DOS it sounds distorted.
Instead, when I start Windows with the correct drivers installed and then I shutdown to DOS the mixer values are fine.
If I can support you please let me know. I can extract the content of the EEPROM and ROM Chips on the card which have the rev 1.4 and 1.04 if that helps.
Reply 754 of 825, by AirIntake
JazeFox wrote on 2025-04-30, 18:21:
I tested v0.82a and it now works perfectly with the onboard Crystal CS4235-KQ. Thanks very much!
Casio BE-300 Advancement Society (be300.org) alumni
Reply 755 of 825, by vanfanel
Hi! I use UNISOUND (latest 0.82a version) on my TinyLlama v2 board, which has a CS4237B on-board.
It works very well, except that Tyrian has WSS address $530 hard-coded and can't be adjusted, but UNISOUND detects/sets WSS on $534, so Tyrian WSS doesn't work.
I have tried exporting "W530" in the BLASTER variable, but UNISOUND insists on using $534 for WSS.
So, is there a way to "convince" UNISOUND to use $530 for WSS on CS4237B audio?
Reply 756 of 825, by JazeFox
Hi! Thank you all for your words 😀
moturimi1 wrote on 2025-05-06, 08:44:
I would like to know if you plan on improving the detection of the Kurzweil Pinnacle soundcard. Unfortunately the card I own is […]
I guess you have a rev.F card (you didn't specify system/card details).
In the next version your card will be detected and initialized. Anyway, I'm afraid that the volume will remain the same. Unisound does not mess with the DSP firmware binaries and code required to manipulate the routing and mixer capabilities.
vanfanel wrote on 2025-05-11, 14:57:
Hi! I use UNISOUND (latest 0.82a version) on my TinyLlama v2 board, which has a CS4237B on-board. It works very well, except tha […]
Tyrian problem with Crystal cards has nothing to do with the WSS Base address (In fact, it's correct, the default for Crystal WSS PnP registers is 0x534, and not 0x530, the original drivers do the same and even PnP BIOS do the same. And Crystal WSS codec will operate perfectly with software/game calls to 0x530). The problem is that AFAIK Tyrian uses hardcoded DMA 0 for WSS. So, for Tyrian yo work with Crystal cards, do something like: SET BLASTER=A220 I5 D0 T4 , and it will work.
Reply 757 of 825, by vanfanel
JazeFox wrote on 2025-05-11, 16:31:
I tried that (setting BLASTER=A220 I5 D0 T4) and that does not work: audio effects are totally silent.
I talked about this with the designer of my board (TinyLlama v2) and he says that the DMA 1 is physically connected to the CS4237B, so DMA 0 can not be used in it's place.
Maybe there's some misunderstanding here? (possibly on my side)
Reply 758 of 825, by 640K!enough
vanfanel wrote on 2025-05-11, 17:05:
The problem is that the processor module used on that design does not expose all of the usual ISA bus features of more traditional designs, so the designer had to make compromises to allow it to have sound hardware at all. Since only DMA 1 was available, and Tyrian only seems to correctly support DMA 0 (for WSS), you are likely out of luck with that title. Whether this is due to a shortcut the programmers took with their WSS support, or the fact that the CS4237B doesn't implement the configuration interface of the original Microsoft board, isn't entirely clear.
It is not a bug with UNISOUND, and isn't something that can be fixed by using Crystal's CWDINIT, either. While the CS4237B does offer a certain amount of flexibility, I don't think any of it will help with this problem. It is a limitation of the SoM used in that system, combined with an apparent inability to use DMA 1 in that title.
Reply 759 of 825, by vanfanel
640K!enough wrote on 2025-05-11, 21:25:
That's great information, everything fits in place now! Many thanks for the explanation! 😀
