Reply 760 of 932, by FreddyV
Hi,
Here is Mod Master XT b27
22/08/2021 Beta 27
- Added BlasterBoard 2.1+ Signed output support. (A Little faster)
- AMD InterWave (GUS PnP) now working and GUS Code simplified.
- TNDLPT Tested.
- OPL3LPT Support added and Tested. (Does not work with SAT/S3M yet)
- CMS and CMSLPT Support added. (For VGM)
- Button added to enable the GUS Line in but not implemented yet.
- Display the Sound Blaster name in the main page.
- Display the LPT2 and Tandy DAC port in the Output menu if available.
- Save the Custom DAC port in the Config File.
- Does not reinit the Text Mode each time a module is played (This can affect some CRT Monitors)
- Corrected a problem in the Vib Volume Slide effect (World of Plastic S3M)
- Various small correction
