VGA Capture Thread
Reply 780 of 1539, by Master1UP
@imi
Unfortunately not. Only buttons are "Resolution change", "Zoom" and "Auto adjust". There's usb port for updates but I haven't searched yet if it can be used to update the firmware or even where I could get the firmware from.
If I find any firmware updates and it makes a difference, I will post results. But for now this is where I am with it. I have been waiting months so I could stream some DOS gaming with friends so I'm fine with this now. I will continue searching and follow any new findings here.
@elianda
Yeah I have some adjusting to do before I stream. I "accidentally" resetted all my OBS settings and scenes so it's couple of days tinkering before I'm ready. I'm not sure if I can make the DOS background black as black without making everything else too dark but I will check on it when I have more time.
Reply 781 of 1539, by imi
I mean the ingame screenshots don't look that bad honestly, but windows looks bad and textmode is filtered to death x3
Reply 782 of 1539, by appiah4
That looks like the Gamma is way off, you need to correct black levels before it looks semi decent.
The MS-DOS and Larry screenshots tell me there is also a good deal of upscale filtering going on as well so you won't get a crisp pixel perfect image out of it, but as far as I am concerned I would be OK with this for recording games as long as it did not cost me an arm.
Reply 783 of 1539, by cvgl
Hello
I would like to get an HDMI signal from my old IBM ValuePoint - 6382 computer
http://ps-2.kev009.com/pcpartnerinfo/ctstips/f02e.htm
There is an S3 graphics card on the motherboard. I bought a simple VGA-HDMI converter and of course the problems started. When i turn on my computer, the IBM logo and memory test appear on the TV (this is 640x480x60Hz). But when the DOS loading starts, the image goes out and the screen is black. The TV displays the message "no signal". The converter in the specification supports a resolution of 640x480 but it does not support and not work for DOS in 720x400x70Hz.
Everything is OK with direct connection from VGA to the same TV (the TV has a VGA input).
What converter could I buy that would correctly convert a VGA image from DOS games in 640x480x60, 640x350x70, 720x400x70 resolution? Ultimately, I want to connect it to the AverMedia card.
Reply 784 of 1539, by MAZter
https://www.ebay.com/itm/Atlona-AT-HD500-VGA- … le/114191056310
Doom is what you want (c) MAZter
Reply 786 of 1539, by ruthan
BTW how 320x200 and 320x240 works, do you need specific support for them? Or they are automatically supported when 640x480? Or other resolutions are supported?
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 787 of 1539, by imi
afaik a VGA gpu outputs those resolutions with double-scan to accomodate 31kHz monitors, so it should be fine.
Reply 788 of 1539, by MAZter
cvgl wrote on 2020-04-18, 06:28:
Not support 720x400:
https://atlona.com/pdf/manuals/AT-HD500.pdf
page 8
It supports input 720x400 without problem, I can't understand what any other kind of support necessary.
Manual says:
• Scales any VESA resolution from 640x480 up to 1920x1200 (or 1080p)
720x400 is vesa resolution, correct?
Usually I setup output as "panscan" option, to save correct aspect ratio regardless of input resolution:
https://www.youtube.com/watch?v=oOHNLioA-f0
Reply 789 of 1539, by elianda
MAZter wrote on 2020-04-24, 20:13:
720x400 is not a VESA resolution as VESA just defines a 80x25 text mode, but no 720x400 graphics mode.
Youtube Channel
Reply 790 of 1539, by cvgl
No one can guarantee that it will work. I have already tested 5 converters and none of them works (it doesn't detect 720x400 mode in DOS). I turned to the seller.
Reply 791 of 1539, by elianda
The AV.io HD most likely is also supported by my alignment tool, as it is based on the same driver backend.
Youtube Channel
Reply 792 of 1539, by Bimmy
cvgl wrote on 2020-04-17, 18:59:
I have been on the lookout for a similar converter and tried several of these cheap solutions (The dime-a-dozen black/white box type you can find everywhere on ebay/ali/amazon etc) None of those seem to support 720x400 70hz textmode until I came across this one at a local electronics store;
It is made by Sanwa Supply (not to be confused with Sanwa Denshi of the arcade switches/buttons) and while it looks identical to the aforementioned dime-a-dozen bunch, this one actually says on the box that it supports 720x400 x 70hz and to my surprise was one of the only manufacturers who openly state all their supported modes on their packaging. The model number is VGA-CVHD2 and is reasonably priced at around 4000 yen or around 35 eur. They can be found on Amazon.co.jp.
Mine should arrive tomorrow and I will update after I've given it a shot 😀
Update:
I've tried the Sanwa Supply converter and this too wouldn't display anything before the OS (i.e. BIOS/POST/DOS etc..) Despite all the claims of the resolutions supported on the box.
However, another box that I had ordered along with it did turn out to work and it was the cheapest of the bunch! Lucky!
The monitor I'm using recognized the BIOS / POST resolution as 640x416 x 70hz rather than 720x400x70 which sounds hella weird but hey, that's what the monitor said, and it actually displayed, unlike all the other boxes.
The box that worked looks like this and cost me 999 yen or like 8-9 eur.
Though even the one in the picture has a green audio jack on the side whereas mine is just a normal metal looking one.
I believe many of these are just reproductions from a lot of different manufacturers based on similar designs using a variety of components and materials...
My advice however is buy a bunch and try them, since they aren't always true to their claims on the packaging / product information.
Ideally from a store where you can get a refund for the ones that didn't work.
I'd really like to see a teardown on a bunch of these to identify what signal processor the good ones use, so people interested in getting them can know what to look out for.
Reply 793 of 1539, by SquallStrife
appiah4 wrote on 2020-04-17, 10:49:
Probably not Gamma, rather the HDMI range, which is something that can (hopefully) be corrected in software.
HDMI signals designed for TVs, for some reason, have RGB values between 16-235, rather than 0-255. Usually in the capture software you can tell your capture card to compensate.
I have to do this when I'm capturing from my Startech VGA2HDMIPro scaler
Reply 794 of 1539, by Master1UP
SquallStrife wrote on 2020-05-19, 02:00:
Probably not Gamma, rather the HDMI range, which is something that can (hopefully) be corrected in software. […]
You might be right. Actually I happened to bump into Gefen VGA-DVI Scaler Plus without power cable on ebay for reasonable price (about 30€) and the results are literally like night and day. I still have to adjust some settings before I stream but so far I'm 100% satisfied.
I contacted the seller about possible firmware updates for the chinese scaler but so far no reply. They told me they will contact the manufacturer about it but I don't think I will hear from them anymore. But anyways here's the comparison of the two.
Reply 795 of 1539, by cvgl
ruthan wrote on 2020-04-18, 15:38:
The converter must support DOS resolution (720x400) from my old computer (IBM 486) because if it will not support, there will be no image. It often happens that the converter recognizes the given resolution on a newer computer (e.g. Core2Duo) but does not recognize it on the old 486.
Will you give me a 100% guarantee that this converter will handle 720x400 from my old 486? And other resolutions? I'm not going to throw $ 500 in the trash. I tested probably from 10 different converters, only two are doing quite well (AverMedia ET110 and Spacetronik HDCVGA01) but also not quite because they do not display the image from some games or incorrectly recognize the basic resolutions, e.g. instead of 720x400 they recognize 724x456 etc.
Reply 796 of 1539, by Bimmy
cvgl wrote on 2020-05-19, 15:59:
I'm not an expert on the matter (and by all means correct me if I'm wrong) but it looks like portions of the front and back porch of the video signal may be incorrectly interpreted by the capture / receiving device as visible screen resolution?
Reply 797 of 1539, by Master1UP
Master1UP wrote on 2020-05-19, 06:46:
Well lets put that somewhere around 50% satisfied. I finally tested my Gefen with a game and I might have faulty unit or is this something to be expected with this device? I tried many settings and adjustments, but I can't seem to do any visible difference.
Especially in the staircase you can see how the darks are brown and muddy and it loses most of the details. In bedroom scene the ceiling is losing most of the detail and stones next to the door are also brown and muddy.
Raising the brightness just brings "crawling ants" more visible on some colors. First I thought it's my cables but that's not the case. I tried many different combinations. Funny thing is that my Chinese scaler works with this game perfectly and it's not blurry like in windows and DOS. At least with this level of detail it doesn't look like it to the eye.
Staircase comparison is with camera because I can't capture yet both with same setup.
If anyone has any advice or can tell if my unit is definitely faulty, please let me know.
Model: EXT-VGA-2-DVISP (Gray)
Reply 798 of 1539, by vvbee
A reminder to all. VCS, the third-party capture software for Datapath capture cards, is up to version 2.0 these days and has added support for Linux as well as implementing many other improvements over what was already a good version 1.0. Targeted especially toward analog retro capture. Free for personal and commercial use.
Also a reminder: second-hand Datapath cards together with VCS can give you professional-quality analog capture for as little as $30 if you also set up a capture box with PCI and Windows XP/7. In my experience, there isn't much if any difference in image quality between the older/cheaper and newer/pricier Datapath models for low-resolution analog capture.
Reply 799 of 1539, by darry
Master1UP wrote on 2020-05-20, 19:36:
Well lets put that somewhere around 50% satisfied. I finally tested my Gefen with a game and I might have faulty unit or is thi […]
If having shimmering/movement that isn't there, try phase adjust on the Gefen . Can't speak for other issue .
