DOSBox ECE (for Windows & Linux)
Reply 780 of 1565, by Charles D. Ward
Thanks for your reply krcroft
I tried applying the patch, and got the following output:
$ zcat dosbox_r4267-cdda_audio_updates-rev13_2.patch.gz | patch -p1
patching file configure.ac
Hunk #1 FAILED at 1.
Hunk #2 FAILED at 514.
Hunk #3 FAILED at 619.
3 out of 3 hunks FAILED -- saving rejects to file configure.ac.rej
patching file Makefile.am
Reversed (or previously applied) patch detected! Assume -R? [n]
Apply anyway? [n]
Skipping patch.
1 out of 1 hunk ignored -- saving rejects to file Makefile.am.rej
patching file src/dos/cdrom.h
Apply anyway? [n]
Skipping patch.
6 out of 6 hunks ignored -- saving rejects to file src/dos/cdrom.h.rej
patching file src/dos/cdrom_image.cpp
Apply anyway? [n]
Skipping patch.
24 out of 24 hunks ignored -- saving rejects to file src/dos/cdrom_image.cpp.rej
patching file src/dos/drive_iso.cpp
The next patch would create the file src/libs/decoders/archive.h,
which already exists! Assume -R? [n]
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/audio_convert.c,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/docs/copying.txt,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/docs/credits.txt,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/docs/license.txt,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/dr_flac.h,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/dr_mp3.h,
Apply anyway? [n]
Skipping patch.
patching file src/libs/decoders/dr_wav.h
The next patch would create the file src/libs/decoders/flac.c,
Show last 99 lines
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/internal/Makefile,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/Makefile.am,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/mp3.cpp,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/mp3_seek_table.cpp,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/mp3_seek_table.h,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/opus.c,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/SDL_sound.c,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/SDL_sound.h,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/SDL_sound_internal.h,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/stb.h,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/stb_vorbis.h,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/stb_vorbis_test.c,
Apply anyway? [n]
Skipping patch.
patching file src/libs/decoders/vorbis.c
The next patch would create the file src/libs/decoders/wav.c,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/xxh3.h,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/xxhash.c,
Apply anyway? [n]
Skipping patch.
The next patch would create the file src/libs/decoders/xxhash.h,
Apply anyway? [n]
Skipping patch.
patching file src/libs/Makefile.am
Apply anyway? [n]
Skipping patch.
1 out of 1 hunk ignored -- saving rejects to file src/libs/Makefile.am.rej
patching file src/Makefile.am
Apply anyway? [n]
Skipping patch.
2 out of 2 hunks ignored -- saving rejects to file src/Makefile.am.rej
The next patch would create the file VERSION,
Apply anyway? [n]
Skipping patch.
I'm running make now,waiting for the result 😀
Edit: this is the result:
In file included from flac.c:46:0:
dr_flac.h: In function ‘drflac_read_pcm_frames_s16__decode_left_side__sse2’:
dr_flac.h:8243:60: warning: implicit declaration of function ‘drflac__mm_packs_interleaved_epi32’ [-Wimplicit-function-declaration]
_mm_storeu_si128((__m128i*)(pOutputSamples + i*8), drflac__mm_packs_interleaved_epi32(left, right));
dr_flac.h:8243:60: error: incompatible type for argument 2 of ‘_mm_storeu_si128’
In file included from dr_flac.h:1052:0,
from flac.c:46:
/usr/lib/gcc/x86_64-linux-gnu/6/include/emmintrin.h:714:1: note: expected ‘__m128i {aka __vector(2) long long int}’ but argument is of type ‘int’
_mm_storeu_si128 (__m128i *__P, __m128i __B)
dr_flac.h: In function ‘drflac_read_pcm_frames_s16__decode_right_side__sse2’:
dr_flac.h:8378:60: error: incompatible type for argument 2 of ‘_mm_storeu_si128’
from flac.c:46:
dr_flac.h: In function ‘drflac_read_pcm_frames_s16__decode_mid_side__sse2’:
dr_flac.h:8593:64: error: incompatible type for argument 2 of ‘_mm_storeu_si128’
from flac.c:46:
dr_flac.h:8629:64: error: incompatible type for argument 2 of ‘_mm_storeu_si128’
from flac.c:46:
dr_flac.h: In function ‘drflac_read_pcm_frames_s16__decode_independent_stereo__sse2’:
dr_flac.h:8738:60: error: incompatible type for argument 2 of ‘_mm_storeu_si128’
from flac.c:46:
Makefile:455: recipe for target 'libdecoders_a-flac.o' failed
make[4]: *** [libdecoders_a-flac.o] Error 1
make[4]: Leaving directory '/mnt/data/Linux Software/DOSBox ECE r4259 (Linux source)/src/libs/decoders'
Makefile:332: recipe for target 'all-recursive' failed
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory '/mnt/data/Linux Software/DOSBox ECE r4259 (Linux source)/src/libs'
Makefile:444: recipe for target 'all-recursive' failed
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory '/mnt/data/Linux Software/DOSBox ECE r4259 (Linux source)/src'
Makefile:396: recipe for target 'all-recursive' failed
Show last 4 lines
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/mnt/data/Linux Software/DOSBox ECE r4259 (Linux source)'
Makefile:337: recipe for target 'all' failed
make: *** [all] Error 2
Reply 781 of 1565, by krcroft
It will apply to vanilla DOSBox SVN 4267 (not ECE).. so it'll get you one patch toward the full set applied in the making of ECE. I'm not sure of the state of the other patches ( in terms of applying clean to current SVN)
Reply 782 of 1565, by Charles D. Ward
I understand, hope Yesterplay80 eventually patches ECE sourcecode then 😀
Reply 783 of 1565, by Charles D. Ward
Made a fresh install of MX Linux 19 RC1 (64 bit)
Spent some time trying to run the DosBox ECE binary, it would complain about the following missing libs:
libasound.so.2
libGL.so.1
libpulse-simple.so.0
libSDL_net-1.2.so.0
libfluidsynth.so.1
libjack.so.0
libreadline.so.7
libX11.so.6
libglib-2.0.so.0
libpng12.so.0
libSDL-1.2.so.0
libz.so.1
After a bit of gooling, realized I needed the following packages in order to get these libs:
libsdl-net1.2
libpng12-0
libfluidsynth1
libasound2
libz1
libx11-dev
libgl1-mesa-glx
libglib2.0
libjack0
libpulse0
libreadline7
I think it is not necessary to download all these packages if you already have the libs, so I made a .tar.gz file and attached it to this post
Just decompress the "lib" folder on the DosBox ECE binary folder, and then run dosbox with the following command:
LD_LIBRARY_PATH=./lib ./dosbox
Reply 784 of 1565, by Charles D. Ward
Latest source code (r4274) gives a different compiling error than r4259:
In file included from glide.cpp:23:
../../include/glide.h:64:10: fatal error: sdk2_glide.h: No such file or directory
#include <sdk2_glide.h>
compilation terminated.
make[4]: *** [Makefile:467: glide.o] Error 1
make[4]: Leaving directory '/mnt/data/Linux Software/ECE/src/hardware'
make[3]: *** [Makefile:487: all-recursive] Error 1
make[3]: Leaving directory '/mnt/data/Linux Software/ECE/src/hardware'
make[2]: *** [Makefile:451: all-recursive] Error 1
make[2]: Leaving directory '/mnt/data/Linux Software/ECE/src'
make[1]: *** [Makefile:396: all-recursive] Error 1
make[1]: Leaving directory '/mnt/data/Linux Software/ECE'
make: *** [Makefile:337: all] Error 2
Reply 785 of 1565, by Yesterplay80
krcroft wrote:
Charles, this was a known issue reported by Yesterplay80 that was fixed ( AUDIO Patch supporting FLAC, Opus, and MP3 audio tracks), but now that you've flagged it we see the update is not in the current ECE sources; maybe Yesterplay80 can generate an updated source pack for you 😀
I just double chcked: I'm using version 13.2 of your patch, I downloaded and compared it with the file I'm uisng and it 99% identical, the missing 1% are the changed folder names and the omitted name changes to DOSBox GIT your patch adds. So that shouldn't be the problem. Though so far I can only speak for the Windows version, since I can't get ECE compiled under Linux because of a problem with the 3Dfx patch atm.
UPDATE: It might be possible, tough, that the Linux version actually still used an older version of your patch, because it is also based on an older SVN. I couldn't get it compiled any more since the latest changes to the 3Dfx patch, so I probably didn't bother checking other patches. However. Today, I got the Linux version compiled again, please give the new source code a try, Charles. It contains all recent patches for sure now! 😀
Charles D. Ward wrote:
Latest source code (r4274) gives a different compiling error than r4259: […]
You need to have the header files from OpenGlide in your include directory: https://sourceforge.net/projects/openglide/
I added them to the ECE source files, too.
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 786 of 1565, by Deffnator
Its possible to play with CRT Shaders or inject it with something like Reshade OpenGL?, pixel perfection is a meme and Retroarch NEC Xm29 shader + Lottes spoiled me a bit.
Reply 787 of 1565, by realnc
RetroArch now has a DOSBox-SVN core. I've been using it for a while now 😀
Reply 788 of 1565, by Deffnator
Retroarch hates Flightsticks and hotas
Reply 789 of 1565, by fr500
I still have a few plans to improve input on my core (though that means developing for RA itself and I'm not fond of doing that anymore)
I'll look into supporting more controllers soon after I finish the new core options code path and improving the disk mounting interface.
Reply 790 of 1565, by Yesterplay80
If you use one of the OpenGL output modes, you can use Reshade with DOSBox ECE, yes: DOSBox ECE (for Windows & Linux)
Reply 791 of 1565, by Srandista
Kisai put updated MUNT patch into MT-32 forum, maybe it's worth to look into.
Re: Munt Reloaded - Development
Reply 792 of 1565, by willow
I don't know if it's possible but dsobox daum incoporated a patch to increase memory size of graphic cards until 8 Mo instead of 2mo by default in dosbox and dosbox ece.
it's neccessary for some dos games that support 1600x1200 with more than 256 colors like pro pinball.
Is it possible to integrate this patch in dosbox ece? I don't know the name of this patch.
Reply 793 of 1565, by pantercat
Hi, just to confirm "DOSBox ECE r4275 (Linux source).7z" compiles cleanly in a Debian system and I'm playing games with no issues so far. Thank you very much for your time maintaining a Linux build too 😀
Reply 794 of 1565, by Yesterplay80
ECE sets 4 MB of video memory by default. Increasing the memory to 8 MB results in graphical problems under Windows 3.11.
You're welcome! 😁
Reply 795 of 1565, by Scandy
Excuse me, surely it has already been asked but it's not easy to search in 40 pages of thread 😉 There's a way to build and run DOSBOX ECE on Raspberry Pi 4?
My main goal is to play DOS titles on Raspberry while maintaining the correct aspect ratio without artifacts, and I heard that DOSBOX "vanilla" has some problems with it.
Thank you|
THE NIGHTLAND is my board + video game for Commodore 64.
Reply 796 of 1565, by gdjacobs
Thank you|
Several ways. I usually use the build tools patch from the Debian source package.
Reply 797 of 1565, by Scandy
Cool!!!
Actually I'm using DOSBOX on a real CRT monitor with a VGA666 and a Raspberry Pi 3. RPi 3 VGA output is set to 640x400, DOSBox is set to normal2x with NO aspect ratio, and I use the CRT trimmers to set the correct aspect ratio: https://twitter.com/alescandy/status/1141430824656625664
Sadly VGA666 has some issues with Raspberry Pi 4, so I'm wondering if I can switch to a LCD monitor, nevertheless correct aspect ratio is fundamental to me. Are you using only a patch applied to vanilla DOSBox, or do you install DOSBox ECE?
Reply 798 of 1565, by gdjacobs
Usually Vanilla DOSBox with NukedOPL applied.
Reply 799 of 1565, by Scandy
So no specific patch for correct aspect ratio?
