Reply 80 of 85, by kagura1050
- Newbie
The Serpent Rider wrote on 2025-11-18, 05:00:With a proper revision of Wolfdale, 4.5 GHz has reasonably high chance of success.
I agree with this. The combination of E8x00 and ASUS motherboards runs at BCLK 470MHz (4.46GHz for E8500) in most cases.
agent_x007 wrote on 2025-05-05, 13:52:Even with multiplier adjustment, you still will see 4.8GHz at 1600MT/s FSB 😉
It's probably best not to try this (unless you want to destroy your board).
My Pentium 4 631 (D0) and Celeron D 347 (D0) easily reach 5GHz at 1.6V with ASUS Commando (which means D0 stepping requires roughly this voltage).
A while ago, I bought a Pentium D 925 (D0) and was aiming for 5GHz with 333x15, but even with a 1.7V setting and Vdroop Mod, I could barely get it to POST at FSB1200 (4.5GHz). What's more, within a few minutes, the "EPS12V connector" (not the VRM!) became so hot that it was too hot to touch (around 60c?).
I think this is beyond the range that a typical VRM on an LGA775 mobo can safely handle.
古いマシンで新しいOS(Linux/NetBSD)を動かすのが好き。
Timezone : UTC+9
