TEDIT v0.60 [MULTI-DOC SUPPORT]
Reply 80 of 82, by cookertron
Version 0.60 released - github.com/cookertron/TEDIT
  • Multi-document support (up to 8 ) - shortcut keys ALT+<n> to select
  • Document selection side panel accessible via F1
  • Projects added to support opening multiple documents
  • Shell to DOS added in the File menu - in combination SHROOM (see igully's post above) can free up memory if tight
  • Added missing keyboard shortcuts
  • File selection dialog issues patched
  • Various other bugs (see changelog)
Please give it a whirl and let me know your thoughts.
Asus P5A v1.06, Gigabyte GA-6BXDS, Soyo SY-5EMA (faulty), Viglen 486, Asus SP97-V
Reply 81 of 82, by Yoghoo
Very busy atm so only did a very quick test. Multi-doc edit works nicely. Thanks. Some issues:
  • Starting editor like: tedit 1.txt 2.txt only opens the first file. It should open all files given on the command line (until max of course).
  • Starting editor like: tedit test.prj opens this file but I expected it would open the files in the project. Opening the project inside the editor works fine btw.
  • Quiting TEDIT and just pressing Y or N does not do anything (as a shortcut)
Reply 82 of 82, by igully
Just gave a quick test to v0.60.
Nothing to say, but thank you!
