Reply 80 of 93, by gsos
@The Solutor: Does DOS Navigator appear, or does it stop on the boot messages? If it
stops, could you photograph the last messages?
My laptop’s built-in keyboard uses our xHCI USB driver, and I’ve also had a USB mouse
working on bare metal, so some support is already there. One current limitation is that
RetroOS initializes only the first xHCI controller it finds; your machine has three.
I’ve attached a smaller diagnostic image that automatically saves the kernel boot log
to C:\KLOG.TXT before starting DOS Navigator. If boot completes but input doesn’t work,
that log should help explain what happened during xHCI discovery. To retrieve it after
reboot, select Persistent disk and have a supported internal FAT or ext4 data volume
available. It cannot save back to the USB stick yet.
@LSS10999: Ideally, I’d like RetroOS to handle the motherboard setup and ISA PnP
initialization itself, so configurations like yours wouldn’t require DOS utilities
before booting.
Your HDA should likely work also, retroos would emulate the soundblaster there.
The problems addressed by EGAFIX and NEWAX are also worth investigating. RetroOS
already provides its own BIOS services for DOS programs, so some equivalent fixes might
fit there, but I’d need to examine what those utilities change before judging the work
involved.
Just to confirm: does the new image still hang at exactly the same point?
