bug report (?) win3.x and latest cvs
Reply 80 of 95, by wd
Rank DOSBox Author
DOSBox Author
There must be log output, otherwise changing the sblaster.cpp would not
be capable of disabling sb functionality.
Reply 81 of 95, by kruwi
UUUPs ....
Visit the end of the internet: www.groskreutz.de
Reply 82 of 95, by kruwi
This is the output:
read mixer 4 write mixer 4 : 37 read mixer 4 read mixer 2e write mixer 2e : ee read mixer 2e write mixer 22 : cc write mixer 4 : […]
read mixer 4
write mixer 4 : 37
read mixer 4
read mixer 2e
write mixer 2e : ee
read mixer 2e
write mixer 22 : cc
write mixer 4 : cc
write mixer 26 : cc
write mixer 28 : cc
write mixer 2e : cc
write mixer a : 0
Reply 83 of 95, by Qbix
Rank DOSBox Author
DOSBox Author
this is the non-working case ?
Water flows down the stream
Reply 84 of 95, by kruwi
Yes. Windows stays silent.
Reply 85 of 95, by wd
Rank DOSBox Author
DOSBox Author
Maybe just for completeness you could try posting the log output with
the old sblaster.cpp (or is it the same?)
Reply 86 of 95, by kruwi
Using the old sblaster.cpp, the output is like this:
read mixer 4 write mixer 4 : 37 read mixer 4 write mixer 4 : ff read mixer 2e write mixer 2e : ee read mixer 2e write mixer 22 : […]
read mixer 4
write mixer 4 : 37
read mixer 4
write mixer 4 : ff
read mixer 2e
write mixer 2e : ee
read mixer 2e
write mixer 22 : cc
write mixer 4 : cc
write mixer 26 : cc
write mixer 28 : cc
write mixer 2e : cc
write mixer a : 0
write mixer e : 0
write mixer e : 0
write mixer e : 0
write mixer e : 0
In both cases (old and new sblaster.cpp) I simply started and quitted windows.
With the old sblaster.cpp I could hear both the start and the exit sound. With the new one, nothing ... .
Reply 87 of 95, by Srecko
Thanks for the log.
read mixer 4
write mixer 4 : 37
read mixer 4
This won't return 37 but 26 with sbpro or sbpro2 (because of two "reserved" bits which are set to 0 on read), although it's strange that it still doesn't work with sb16 setting where it should return same value (maybe it stops somewhere else). I will check with the driver that I found.
Reply 88 of 95, by wd
Rank DOSBox Author
DOSBox Author
Maybe the register should get a different initialisation value? As they read
something from reg4 and (supposedly) write that (modified) back.
Reply 89 of 95, by Srecko
Found this bug (missing brackets):
-(((_WHICH_[0] & 0x1e) << 3) | ((_WHICH_[1] & 0x1e) >> 1) & (sb.type==SBT_16 ? 0xff:0xee))
+((((_WHICH_[0] & 0x1e) << 3) | ((_WHICH_[1] & 0x1e) >> 1)) & (sb.type==SBT_16 ? 0xff:0xee))
Could be a cause for this regression (driver will read 0xfe, not 0xee from 0x2e reg).
Regarding default values, we set volumes for 0x4,0x22,0x26 to 31 (to get higher volume in games), while default should be 20 (or 0xaa in sbpro reg). Default for 0x2e is 0 which is correct in dosbox.
Version of sbpro2 driver I have here is a bit different from kruwi's. It doesn't work with older mixer code either, nor with above fix, and it reads only the line-in register:
<cut> issue with my driver doesn't seem to be mixer related, aborts after reading dsp version several times.
Reply 90 of 95, by kruwi
sbtype=sb16 in combination with the sb16 drivers is actually working.
Reply 91 of 95, by Srecko
How about Pro2 driver? Is it better with above bracket correction or still refuses to initialize?
Reply 92 of 95, by wd
Rank DOSBox Author
DOSBox Author
kruwi: please check out current sources and re-test the problem with
the sbpro driver. If it doesn't work add the log messages again and
see if the output changed.
Reply 93 of 95, by kruwi
Quite funny. With the current sources and the setting sbtype=sb16, the sbpro2 drivers are working. They are not working, however, if I try sbtype=sbpro2.
Now checking log files ...
Reply 94 of 95, by kruwi
sbtype=sb16, using the sbpro2 drivers (working):
read mixer 4
write mixer 4 : 37
read mixer 4
write mixer 4 : ff
read mixer 2e
write mixer 2e : ee
read mixer 2e
write mixer 22 : cc
write mixer 4 : cc
write mixer 26 : cc
write mixer 28 : cc
write mixer 2e : cc
write mixer a : 0
write mixer e : 0
write mixer e : 0
write mixer e : 0
write mixer e : 0
sbtype=sbpro2, using the sbpro2 drivers, not working:
read mixer 4
write mixer 4 : 37
read mixer 4
read mixer 2e
write mixer 2e : ee
read mixer 2e
write mixer 22 : cc
write mixer 4 : cc
write mixer 26 : cc
write mixer 28 : cc
write mixer 2e : cc
write mixer a : 0
Reply 95 of 95, by Srecko
It's the 37->26 issue.
Only difference between sbpro2 and sb16 is last precision bit for each stereo volume, it seems that driver assumes 4-bit precision while sbpro/pro2 *should* have 3-bit precision - probably it does, but driver still expects last bit to be preserved ( Creative breaking their own nice-coding guidelines from SB SDK).
Shoud work if we remove sb.type==SBT_16 checks from macros SETPROVOL and MAKEPROVOL and assume as if they were true.
