Reply 80 of 3179, by Marmes
- Member
wrote:My workflow basically goes like this:
Scan both sides (1200dpi), correct the scale in photoshop so vias match up perfectly or at least very close, convert to 2 color black & white, convert to .dxf, convert with "Eagle Power Tools" to a script that draws said black & white image to a dummy layer, start redrawing 😀 One major issue is getting the scale right.Once everything is redrawn, start deriving the schematic using Eagle's Electric Rule check so layout and schematic become consistent (that part is really tedious).
Circad does all that inside 😐 Would you send me the raw scanned pictures? So I can show you?
I also need dimensions of board. And that's it 😀
I forgot to ask, is it 4 layers or 2 layers?
Cheers!
