PCMCIA Graphics and Video decoding cards
Reply 80 of 83, by amijim
Back in 2000 I used to buy Gateway laprops from a liquidator in USA and among the lots there were two Kingmax ZV port DVD accelerators .I guess they were remnants from the old Gateway Solo 9100.Those were the happy days on computing !
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
Reply 81 of 83, by lolo799
amijim wrote on 2026-02-03, 07:00:
The dongle is dangling!
Here's the official website for it:
https://web.archive.org/web/20000309101912/ht … oduct/p06a.html
Kahenraz wrote on 2026-01-24, 23:40:
That's a DirectX 8 benchmark and might be too challenging for it. How does it fare with 3DMark 99?
I had to use a BX motherboard with a Celeron 400, an Cirrus Logic card and a pci to cardbus adapter to run 3dMark99.
The laptops I tried (Compaq Armada 1590, Samsung X10) didn't like the card under Win98 as a primary output, memory range conflicts between the internal card and the cbmlx2.
I used a Dell X300 with a mobile Pentium 1.2GHz for 3dMark2001 the other day.
The attachment cbmlx2-3dmark99-640.png is no longer available
The attachment cbmlx2-3dmark99-800.png is no longer available
Reply 82 of 83, by Kahenraz
Did it render correctly, though? And how was the FPS on the first benchmark?
Reply 83 of 83, by lolo799
Kahenraz wrote on 2026-02-05, 06:08:
I didn't look at the detailed results, fps was barely better than in 3dmark2001 if I had to guess.
You could see the picture getting drawn on screen from front to back, then the weapon and finishing with the hud.
Also guessing, the Unreal intro flyby probably topped at 10fps.
