Reply 80 of 467, by Scali
root42 wrote:
What do I need softwarewise? Can I simply fire up Zak McKracken or Maniac Mansion and it will detect the card?
If you have the card configured for address C0h, it will just work as-is (on PC/XT class machines at least, ATs and newer have the second DMA controller at address C0h, in which case using the address may or may not work. It works on my 286 clone anyway. I lose the second DMA controller, but that one is rarely used).
For any other address, you will need a patched version of the game.
Reply 81 of 467, by matze79
You also should run the SNDOFF Utility,
some Games will not work correctly without it, as channels are still playing noise if not muted correctly.
Reply 82 of 467, by Great Hierophant
Wouldn't he need a patched version of the game when using this sound card in any system? I believe Maniac and Zak do a "Is this computer a Tandy 1000" check before loading the Tandy music driver.
Reply 83 of 467, by Scali
Ah yes, you're right of course. Many games will only enable Tandy audio when they detect a Tandy BIOS (or PCjr).
So in those cases, you need a patched game even for port C0h.
Most Sierra games do not have this check though, afaik, so those would be easy to test.
Reply 84 of 467, by root42
Ok, I'll probably test with Space Quest 3 first, since I already have it installed on the 286. I also have the missing capacitors installed and the ATTINY programmed. Will test it tonight then! I'll try to make a video of that. So fingers crossed the whole thing doesn't explode. 😀
I had to guesstimate the positioning of C4 and the other electrolytic at the second potentiometer though. From the pictures it looks like their negative side / cathod is facing each other.
YouTube and Bonus
Reply 85 of 467, by matze79
I'm not sure if space quest needs the patch 😀
Take a look here:
ftp://ftp.oldskool.org/pub/TandySoundPatches/Info/README.txt
Minus is in the middle for the two 47uf on the variable resistor.. i will reroute next board for better assembly 😀
Reply 86 of 467, by root42
Allright, soundcards are finished and working. Made a video:
https://youtu.be/tTftxRXyC-k
Tested with SQ3, Maniac Mansion, Zak McKracken and Stunts.
Very nice. Although it sounds a bit off. Is that because of the AN variant of the IC?
YouTube and Bonus
Reply 87 of 467, by Scali
It might be because Tandy used a clone, the NCR 8496. This has a slightly different noise channel. Since most games were made for Tandy, not PCjr, the NCR 8496 is probably the 'correct' sounding chip, and the SN76489/SN76496 can sound a bit 'wrong'.
The chips are pin-compatible, so you could drop in a NCR 8496 in this card if you can find one.
Reply 88 of 467, by root42
Well, the NCR chips seem to be rare. Can't find any after a quick search. However, my card definitely is missing out on the drum sounds. Either the IC is broken, or you are right that the NCR version sounds much different. I have two other TI chips, so I will test them. Maybe this one is flaky....
YouTube and Bonus
Reply 89 of 467, by matze79
Also tried to source the original ic but can't find it anywhere.
nice Video 😀 its very well done!, what do you use to capture video ?
Did you also use PC-Speaker Mix in ? because some Games use that as fourth Voice.
Reply 90 of 467, by root42
I will keep an eye out for the NCR ICs but have little hope. The TI variant seems to be so much more common, since it was also used in so many arcade machines and consoles.
I am simply using my iPhone SE for filming my desk, and OSSC + a cheap no name USB3.0 HDMI capture device on the Mac. I use OBS for capture and iMovie to quickly edit the video.
I did not yet connect the PC Speaker, but will do so soon-ish. Need to create a cable. I have none ready.
YouTube and Bonus
Reply 91 of 467, by matze79
Be aware, its not short circuit safe 😀 if you connect in reverse your cable may burn.
I have to figure a way todo this better.
Stunts for example plays sounds over PC-Speaker, so you're missing a channel.
Reply 92 of 467, by root42
Ok, I will triple check the connections... Hope they match the 4 pin connector on my 286 board...
Did you test your boards with Maniac Mansion or Zak? I feel that I am totally missing the drums. The videos that I find on YouTube sound very different...
YouTube and Bonus
Reply 93 of 467, by matze79
EDIT: link below
Reply 95 of 467, by matze79
Yes 😀
i never heard maniac manison on original tandy..
but i found out that variants of SN76489's are sounding slightly different..
maybe this can be used for pseudo stereo 😉
Reply 96 of 467, by root42
I will definitely try out my second card and test the third IC I have. There might also be some arriving from China later this month... Maybe I have a defective IC...?
YouTube and Bonus
Reply 97 of 467, by root42
Ok, I tested the second card, and it sounds the same. So I think it is due to the IC type itself. However, the v1 of Maniac Mansion, which is included in DOTT sounds better I would say:
https://youtu.be/suG1Tb-KLAE
It has much more volume in the drums section. So it might be that the later games were coded for a different chip, maybe the NCR variant... But it's hard to tell without having that chip to try out... If ANYONE gets hold of some... tell me! 😀
YouTube and Bonus
Reply 98 of 467, by root42
One more game tested: Loom EGA (Paramers: loom v ts mo)
https://youtu.be/X9nWdAWMFvc
YouTube and Bonus
