Slot 1 vs Super Socket 7
Reply 80 of 84, by enaiel
Doornkaat wrote on 2020-10-13, 15:23:
What would cause a permanent reset?
Lots of things. My first idea is a missing or wrongly set CMOS jumper or missing CMOS battery but it could also be caused by missing power good signal, a bad or maybe incompatible CPU, all sorts of defective ICs... It's anyone's guess really.
BTW, you were right about the permanent reset. I just noticed the reset LED is constantly lit on the diagnostic card.
TechieDude wrote on 2020-10-16, 22:41:
Hmm, have you tried cleaning the slots and the DIMMs? A toothbrush with rubbing alcohol works well for the former, and an eraser can work surprisingly well for the latter. However, since you mention the diagnostic card doesn't show anything, that might be a sign of something deeper. IIRC a diagnostic card should have shown something, even if it were a RAM issue, never used one though tbh. (Can anyone who has used one chime in?) I have a hunch it might be the BIOS chip. Would you happen to have an EEPROM burner?
I don't have an EEPROM burner, though I have been wanting to buy one for a while.
But I think I might try and get a new PSU first. Any suggestions for a good mATX PSU for a Socket 370 system? Regular sized PSUs will not fit in this case.
H/W: VIA C3 DOS PC | PIII-S Tualatin Win98SE PC
S/W: VIAFSB FSB Util | VIAXFG SB Config Util
Reply 81 of 84, by dr_st
Permanent reset, eh? Is there a chance the reset switch jumper on the board has a short?
Reply 82 of 84, by enaiel
I don't see any sign of a short on the reset pins.
I can only find a couple of decent mATX / compact SFX PSUs that will fit in this case:
1. Seasonic 200SFD - released around 2003
2. FSP300-60GHS - released around 2009
Any suggestions on which one would be better? I'm leaning towards the FSP because it would be slightly newer.
Reply 83 of 84, by TechieDude
Before you go ahead and buy a PSU, do you have any other PSUs to test on your motherboard or other motherboards to test with the same PSU?
Reply 84 of 84, by enaiel
TechieDude wrote on 2020-10-17, 19:27:
I don't have another PSU lying around. The PSU in the case still works with the old motherboard that I am trying to replace because it doesn't have any ISA slots, or any support for VIA C3 CPUs. I thought the theory was that the new motherboard needed more power than the old one to powerup.
