Mini ISA ROM Card
Reply 81 of 88, by froller
douglar wrote on 2025-03-14, 14:57:
Is a Gerber file available for your DIP32 ROM card?
Is there any DIP-32 EEPROM less than 512kbit (64kB)?
It requires more complex address decoding or it will just waste address space and possibly overlap with the existing OPTROMs.
So it requires to change the schematic completely not just re-route the gerbers.
▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ 100%
Virus check complete. All viruses are working properly.
Reply 82 of 88, by douglar
froller wrote on 2025-03-18, 13:00:
Sure seems like most DIP32 eeprom devices that are Dip32 are larger than 64KB
The poster I was replying to had a Dip32 “Disk on chip” adapter, so these are larger than 64KB devices. I’d like to make one with diagnostic tools on it.
Reply 86 of 88, by dexterff8
remembering that XTRAMTEST was developed by David Giller and Adrian Black all credits to them
https://github.com/ki3v/xtramtest
Reply 87 of 88, by kingcake
Veeb0rg wrote on 2024-08-25, 09:45:
Well this won't work for the PLOP boot manager I was hoping to use its a 64KB image so I'd need a 27c512 chip. Guess At Least I'll have something I can put xtide on.
plop is a PCI option rom. Not an ISA option rom. The two are very different. You'd need a PCI NIC with EEPROM socket for plop.
Reply 88 of 88, by Linoleum
I built one of those cards (the EEPROM version), and I’m running into a strange issue. It behaves as if it needs to “warm up” for about two minutes before XTIDE will actually start during boot. Until then, the system just skips the ROM entirely and gives me a generic “please insert floppy” error.
The machine is a 386 with an MSI MS‑3119 motherboard using an AMIBIOS. I tried enabling the full RAM count at startup, but that didn’t help. I also looked for anything resembling a FAST boot option to disable, but found nothing. I also build two of those and they both have the same problem...
Has anyone seen this kind of behavior before, or have an idea what might be causing it?
Update: after testing the ROM cards in other systems, the problem is linked to that 386 MSI motherboard. Ugh…
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
