Reply 80 of 156, by Sphere478
weedeewee wrote on 2022-05-11, 21:50:
Jura Tastatura wrote on 2022-05-11, 18:22:
Just an idea, to make similar adapter in the same format but 24pin atx -> 20pin atx that would also give -5v to mbo from modern atx psu. I'd buy that, been searching for a long time but only seen atx-at adapters...
Its not a PCB but easiest way to do what you need is get a fully wired 24 atx to 20 atx cable and solder in a 7905 and two capacitors, someone made a small pcb for the components and it's here on the forum but I'm too sleepy to find the link to it.
also, I think the title of this thread should be changed to AT pico adapter :-p
Yeah, that solution would work pretty well. Where is that link btw..? That diamond shaped pcb.
Sphere's PCB projects.
Reply 81 of 156, by weedeewee
Sphere478 wrote on 2022-05-11, 22:01:
yeah, I think that was it.
Do not ask Why !
Reply 82 of 156, by Sphere478
Here it is
Re: New solutions to the ATX -5V problem
Reply 83 of 156, by Jura Tastatura
Yeah, but I want all the bling-bling, leds, display, like on that smart ATX-AT adapter. 😁
Reply 84 of 156, by Sphere478
Note: error cap position is reversed
gerbers.zip
150.25 KiB
47 downloads
Here is the gerber with that redundant trace removed^
here you can see it's gone (green) and that the via attaches to the 5v plane anyway. (red)
    126.99 KiB
    143.55 KiB
Reply 85 of 156, by Sphere478
If someone wants to suggest a IC and footprint for making the power switch work with a momentary, and draw a schematic I can give a try at making it fit.
Reply 86 of 156, by weedeewee
something like this? https://danyk.cz/zap-vyp_en.html
Do not ask Why !
Reply 87 of 156, by Sphere478
weedeewee wrote on 2022-05-13, 06:34:
Looks like 6? Components?
2 transistors, few resistors and a capacitor.
That’s gonna be difficult to fit…
If we switch to a smd -5v transistor that could save a small amount of room, 🤔
Reply 88 of 156, by Sphere478
Lookin good..
(This is the previous version.)
    1.52 MiB
    1.47 MiB
Reply 90 of 156, by Sphere478
CalamityLime wrote on 2022-06-03, 08:30:
hmmm, interesting.
How much juice does the 12v brick need to have?
the power supply that feeds the pico psu?
wattage divided by 12v
so, quite a bit 🤣 180w psu would require a 15a 12v brick.
If anyone needs one (pcbs) lemme know.
Reply 91 of 156, by CalamityLime
At that much juice you may want to look into a 4 pin connector for power like on this brick
https://www.mini-itx.com/~192w-ac-4pin
Be Happy, it's only going to get worse.
- Projects
Limes Strange 3D models
USB-2-232
Reply 92 of 156, by Sphere478
CalamityLime wrote on 2022-06-03, 14:26:
Honestly, a car battery charger and a battery would be a good source.
Or a controller and a solar panel with battery
These pico psus seem to be largely carputer oriented.
Reply 93 of 156, by CalamityLime
there is the M2-ATX, looks like that's made to take car/boat batteries.
I've seen the pico psu pop up in a few things. A good example would be what tech tangents did with some PC that had a special psu.
It is tempting to try it for something but I don't have a good use case myself.
- Projects
USB-2-232
Reply 94 of 156, by Sphere478
Oh btw, some newer psus are 12v only. You could use another psu…. Kinda defeats the point though 🤣
In any case, lets not forget this adapter works with normal psus also.
Reply 95 of 156, by CalamityLime
Repost from another thread to put it in a more suitable thread
3.3 from the pico at could be handy. You'd want a nice stable connector
Some simple feedback:
Pads:
Make the pads for the ATX connector larger (and the AT connector if there's space). The pads you have are on the smaller side, I think you'll find that solder will ball up on the conductor itself without a good contact to the pad. I've had issues with tiny pads doing this on even leaded solder.
Traces
I do see that you have nice thick traces for the -12 and -5 volt rails but to make room for the pads here are some numbers that might help:
You have the thick traces at around 50mil (1.25mm) which is good for around 1.4amps but most negative rails are about half an amp to an amp.
You're not going to see a whole amp on either the -12 or -5 but to accommodate an amp you want around 32mil which is about 0.8mm.
For PWR_OK
It's a signal line so you don't need much. To accommodate say half an amp (can't find a proper spec but it feels right) you want a trace about 0.35mm
I'm giving trace thickness measurements based on 1oz copper, if you're using 2oz copper than you can half the thickness.
Hope that helps a bit.
I had to find some of information on trace thickness for the USB-2-232-KBD to deal with RGB keyboards. Ultimately it came down to fitting the thickest trace I could fit.
- Projects
USB-2-232
Reply 96 of 156, by CalamityLime
I'm thinking about the 3.3v line and I'm thinking that it should probably be controlled by a mosfet.
The power good goes high to tell your computer that the rails have stabilized and it's safe to use the power.
Especially in my case where I'm thinking of pumping the 3.3 into the cpu, it would be nice to have that get power when the 3.3 is good.
I think the easiest circuit for that kind of switching would be an nchannel mosfet on the high side, probably with 2 resistors and a cap. Been a bit since I messed with mosfets and I feel like I never really understood them so I'd have to have a look into it.
- Projects
USB-2-232
Reply 97 of 156, by Sphere478
If using a mosfet you probably would use the 5v rail because of forwarding losses through transistors.
Anyway, I believe there were AT mobos that used the power supply's 3.3v for the cpu they had a extra connector. If I recall correctly
Reply 98 of 156, by CalamityLime
I was thinking about your comment about voltage loss.
The on resistance of a p channel mos should be about 0.1 - 0.2 ohm. For argument sake lets say it's 0.2 Ohm.
I measured the resistance across power and ground of my socket 3 486 and measured 7000 Ohm. (hopefully esd didn't kill it)
Using those numbers as reference the voltage drop across the mos should be about 0.0001 volts. On paper as I understand it, the reality is probably a bit higher but even so should be within tolerance.
To help with temps then it should probably have 2 phases.
A resistor from source to gate should keep it off then another nchannel mos to switch it on from the 5v pwr-ok line should switch on the circuit. Looking something like the image attached.
- Projects
USB-2-232
Reply 99 of 156, by Sphere478
Maybe I’m wrong, but I could have sworn that there was like a half volt give or take drop passing through any transistor or diode. Because of forwarding losses
