Shuttle Hot 433 won't POST
Reply 80 of 84, by jakethompson1
Gary.H wrote on 2022-07-09, 19:23:
Runs reliably at 133 MHz, occasional freeze at 150Mhz and hardly at all at 160Mhz
Have fitted a 2-pin fan to the heatsink but am unsure where to power it from ? There seems to be no documented fan pins on the motherboard so a 2-pin adapter from a Molex PSU connector ?
Correct.
Many of the CPUs used with this board would have only a heatsink with the hope that case air circulation was enough to keep it cool...
And as to 150 MHz and 160 MHz, those are of course overclocked rates so you may need a higher voltage. Since it's 3.45 V +/- 0.15 V you technically aren't even overvolting until you go past 3.6.
Reply 81 of 84, by Gary.H
Interestingly I watched a YouTube video of someone o/c'ing an AMD 5x86 to 160Mhz at 3.3 volts ?
My 150Mhz o/c is much more stable as the sun has gone down ambient air temps have dropped.
This seems to confirm my suspicion that I just need more cooling for a reliable o/c
Reply 82 of 84, by Gary.H
So.......
Mouse troubles !
The PS/2 mouse port on my Shuttle HOT 433 motherboard seems not to work which is common judging by my research on here 🙁
So I've gone for a serial mouse instead.
Can't get any sign of life out of my PS/2 and Serial Microsoft mouse on any COM port with either mouse.com or the Cute Mouse driver.
So I bought a Belkin serial mouse which IS recognised by both drivers but will not recognise horizontal movement, only forward and back movement ( buttons do work ) 🙁
Belkin mouse was NOS and the box appeared unopened.
Faulty Belkin mouse hardware or a driver issue ?
Reply 83 of 84, by mkarcher
Gary.H wrote on 2022-07-09, 20:45:
Am5x86 processors running at 160MHz at 3.3V are quite common. But you absolutely need airflow on the heat sink for stable operation when you overclock these chips. Even 133MHz without a fan can be borderline depending on heatsink size and air flow in the case.
Reply 84 of 84, by Gary.H
My (Am486 Dx5 W16BGC) runs fine at 150Mhz (with a HSF) but will POST but not boot DOS at 160Mhz at all.
I have another ADZ AMD 5x86 so will give that a go at 160.
