Asus board went nuts
Reply 80 of 82, by ediflorianUS
bogdanpaulb wrote on 2023-03-07, 11:28:
You can't 'reflow' with a hair drier not in a million years but you can use it to evaporate faster ipa in case some went under t […]
ediflorianUS wrote on 2023-03-07, 09:52:
BTW , nice hdd on the floor :D […]
BTW , nice hdd on the floor 😁
Can you bridge the power button pins? see if it starts? don't reflow with hair drier , not worth the risk.
did you try manual fsb+volt setting ? see manual http://dlcdnet.asus.com/pub/ASUS/mb/sock370/8 … /tusl2c-104.pdf
did you reposition the CPU? clear the cmos? (with no cpu in) , plug new 3v bat?
did you clean with contact cleaner or acetone the traces in photo? did you check the continuity of the traces?
You can't 'reflow' with a hair drier not in a million years but you can use it to evaporate faster ipa in case some went under the south bridge.
bogdanpaulb wrote on 2023-03-07, 06:39:
Then can you do this ? 'Can you measure '2'3'4'5'
on ps2 port? why pin 2?
('5' is next to '4' and not the jumper)
Open the pic that's attached to the message , look , and you will understand ('1'2'3'4'5' are not the pins of the ps2 port but points to measure ).
[/quote]
Bine Bogdan-Paul, fie-ti voia ta ,
Amin.
I rather soak the board in WD40 than water, but it's your choice I have multiple laptop problems I am unable to fix.(these days). - Desktops seem a breeze compared.
My 80486-S i66 Project
Reply 81 of 82, by Nemo1985
ediflorianUS wrote on 2023-03-08, 13:56:
Amin.
[/quote]
Soak the board in wd40 it would mean to buy plenty of them.
Also wd40 is different from plain ipa? I mean wd40 there are several products with that brand...
Reply 82 of 82, by ediflorianUS
WD40 stock is for corrosion cleaning and lubrifying . and WD40 silicone is for shine+protecting against humidity and future degradation. alcohol only partially cleans the parts/board , its ok but not doing anything against corrosion or stuck dust under chips(IC's).
