Reply 82 of 315, by chuky
Version 002 and 003 hang at the same place. Version 002 is behaves the same, but version 003 has wrong text textures in the pre-race screen but not in the credits. In the pre-race screen, the top half of the text is fine, but the bottom half is the alphabet texture, or the texture of digit numbers. In the credits, text and the Bizzare Creation textures are fine with version 003 (I didn't wait for the Psygnosis texture to appear). Maybe it's pre-made images and not actual text in the credits.
In the logs, I didn't run the credits with version 003.
Reply 83 of 315, by sharangad
Try this:
https://1drv.ms/u/s!As-dKk-N73dSlwAMo-Zu9Ad0nTvO
MD5: 971fa7785a3869eede325f6e2c46e2b8
The textures should look ok again in the menu and pre-race screens.
There's a dll function (imported by ID instead of name), which was previously fudged. Now it's handled correctly. I'm not entirely convinced this will work.
https://patreon.com/Rready
Reply 84 of 315, by chuky
This time the pre-race screen looks fine (it wasn't in 11-16-003), but the menu and the credits don't display right. I took screenshots. The game still hangs after the pre-race screen. Screenshots have the same resolution, I don't know why vogons shows one bigger.
I put 3 logs, 1 with the game hanging after the pre-race, 1 going to the credits and back to the menu and quitting, and 1 just starting the game and quitting from the menu.
Reply 85 of 315, by sharangad
I think there's a version number mismatch copying the files across:
Check the timestamps and possibly the MD5s.
This should still lockup, but menus and everything else should render correctly:
https://1drv.ms/u/s!As-dKk-N73dSlwEMo-Zu9Ad0nTvO
MD5: eaad2f4734ca15c8955f406a38588c03
Verite.dll MD5: 129ff20a822db6da63458ffd870283be
Redline.dll MD5: 8e14542687f16402eee02d8294961e62
Timestamps at my end: 18 Nov-23 13:51 (GMT + 0530). Your timestamps may differ.
Reply 86 of 315, by chuky
With this version the menus, the credits and the pre-race screen look fine. The game still hangs after the pre-race screen.
I checked the md5 of versions 11-18.001 and 11-18.002 on the test computer in Windows ME and they are what you posted. I tried again version 001 and it still has the same issue as previously. When going from 001 to 002, dates are these (I'm in GMT+1):
verite.dll 2023-11-18 4:55:07 -> 9:21:14
redline.dll 2023-11-18 5:00:04 -> 9:21:06
Reply 87 of 315, by sharangad
chuky wrote on 2023-11-18, 17:32:
With this version the menus, the credits and the pre-race screen look fine. The game still hangs after the pre-race screen. […]
BTW, the black streak in the end credits, some polygons darkening, is there in the actual game. There's a dark shimmer across the image.
Reply 88 of 315, by sharangad
One final attempt before I call it quits:
https://1drv.ms/u/s!As-dKk-N73dSlwoMo-Zu9Ad0nTvO
MD5: f8b73745f7bca6035bffc25e466eb588
This no longer preserves stack stack on entry to calls. I *don't* think this will make much of a difference , other than maybe introducing new bugs. It will once and for all eliminate the possibility that wrapper code is messing things up. Or it could fail completely.
Reply 89 of 315, by chuky
The program crashes when I try to start it. The Verite log file is created and empty, but the Redline log file is not created.
I get a message like this one:
Application error C:\PROGRAM FILES\FORMULA1\F1RED.EXE
The instruction at 00409e9f referenced memory at 02c33fb8
The memory could not be written
Click on OK to terminate the application
Reply 90 of 315, by sharangad
chuky wrote on 2023-11-28, 13:13:
The program crashes when I try to start it. The Verite log file is created and empty, but the Redline log file is not created. […]
Yikes! Sorry. I guess that was a bad idea.
Reply 95 of 315, by sharangad
It looks to be an issue with the callback function, which is never called by the menu or the credits screens.
[EDIT] I use a placeholder because the calling convention is different. At least that's what RReady does. I think this needs something slightly different.
Reply 97 of 315, by RaVeN-05
logs with new build, (last, current)
tried to start Quick Race , heard announcer, no music, black screen just after loading, before even race starts black screen where should be 3d scene
will try credits
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 99 of 315, by RaVeN-05
where is credits? i found checkered flag weaving (this seems from polygons)
tried to navigate menu seems works, ofc very slow, can you make builds with logging disabled also along with logging too? maybe its so slow even single 3d scene frame can't be rendered . The 16 seconds in main menu tics very slow like one in game sec is actually 45 real world seconds.
Will try previous build with checkered flag
