Heads Up: Roland Sound Canvas VA VSTi Plugin!
Reply 800 of 801, by Falcosoft
zaphod77 wrote on Today, 13:29:
Here's what i would actually like to see among the output soundfonts. […]
1) sc55mkII with CTF
2) sc88 with ctf
3) sc88pro with XG mode and ctf
4) 8820 with xg mode and ctf.
number 1 is actually the one i'm most interested in. something that with a fully compliant synth (fluid/bassmidi/spessasynth)should playback the three midis i've linked correctly.
CTF is not a property of the SF2 soundfont itself. But all known SF2 based synths (including Sound Blaster's HW SF2 synths) support a simplified form of the SC-55 CTF by default. That is in case of missing instruments they fall back to Bank 0 (Capital Tones) in case of melodic channels and Program 0 (GM/GS Standard Kit) in case of a Drum channel.
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 801 of 801, by zaphod77
It can certainly be put into a soundfont directly, if the synth doesn't already do it, simply by adding instrument definitions that implement the fallback directly.
And yes, i remember that real creative cards did have a fallback. I'm not sure if it was direct to bank zero, or if it would pick the highest bank that was lower than the one with the missing instrument.
