Reply 800 of 903, by XavierX
Zoomer wrote on 2024-11-19, 22:31:However, if this is indeed connected to SATA3 version, then you should be looking for the devices, that allow forcing the SATA version with jumpers, I think.
OK, thanks - I'll look into this further. I wonder if it's just going to be easier to find an older IDE drive and use that for the OS and a few programs?
Then I can use the more modern drives for storage, which I presume won't cause as many issues as using one for the OS drive.
