Reply 8040 of 57584, by kithylin
- l33t
wrote:That looks like a cross between a Tekram P5T30 and a Aopen / Jetway J-656C - IDE connectors are in the same place as on the Jetw […]
wrote:Unknown Socket 7 board with Pentium 166:
http://imgur.com/YbGLi7ZThat looks like a cross between a Tekram P5T30 and a Aopen / Jetway J-656C - IDE connectors are in the same place as on the Jetway and jumper layout is nearly identical to the Tekram. The only difference between it and the Jetway is the presence of the SD-RAM slot - and the Tekram has 4 PCI slots.
By overall layout and PCB color I'd say it's an OEM Tekram board.
Unrelated, I'm getting another lot delivered next week witch contains some socket 7 boards witch are of almost of no use to me - but if I don't take them, they'll be scrapped... 🙁
I'm keeping the I/O cards - all of them - the 16MHz 286 board (with what looks like a co-processor???), the memory modules, the Chips ISA video card and of course the Creative Voodoo 2.
The question is - are any of the socket 7 boards in the pictures below worth saving? I spotted a Biostar board (one of my favorite brands) with the Intel chipset and a PS/2 port under the AT keyboard connector - but I don't like the fact that it has a Dallas RTC with a built in battery - I might keep that... The ATX Socket 7 board also looks interesting since it has those big PCI slots (and I have a SCSI card that fits it) - but it looks pretty damaged (nothing I can't fix tough). What about the rest? would you guys get any of them?
Most of those look like OEM boards, and most likely won't work normally on their own without some specific bits that came with that system. The ones that are stand-alone have soldered on Dallas RTC chips. Which may work but some day the chips will run out and make the boards mostly useless. The one that is interesting is the yellowish 286 motherboard, with the math co-processor installed and 30pin ram slots. Those ram slots are rather unusual for a 286 board. But.. the battery looks to of leaked and may of damaged the motherboard, so need to look at that. It might work though.
There's that one intel server motherboard with the 66 Mhz PCI slots. That's worth saving and trying to get working at least, probably. Shame it doesn't have AGP though. If it was me I would just strip down the oem boards for ram/battery/jumpers then toss em. That's me, though.
