80486 BIOS image collection
Reply 81 of 191, by BreakPoint
Manufacturer/Identifier: Zida Tomato 4DPS VER 1.0 (PCI400-2)
Chipset: SiS 85C496/85C497 (OR/OT revision)
BIOS/Version: 4DPS VER 1.4 - AWARD
BIOS String: 11/23/95-SiS-496-497/A/B-2A4IBZ11C-00
My CPU collection - Looking for hardware in Ukraine - Ukraine vintage PC forum
Reply 86 of 191, by waterbeesje
Aquarius MB4-DUV rev 3.1
Chipset: UMC498F
BIOS/Version: Award, R3.1, dump attached
The attachment IMG_20210307_105455~2.jpg is no longer available
The attachment MB4-DUV31.zip is no longer available
The attachment MB4-DUV31BIOS.zip is no longer available
sidenote: I did part the BIOS file earlier in a different thread, knowing it's probably better of here... But I didn't have a photo of the mobo yet
(BIOS the same as this post: Re: BIOS image collection - requests, discussion etc )
Stuck at 10MHz...
Reply 87 of 191, by AskNotes
Manufacturer: FIRST INTERNATIONAL COMPUTER, INC. ?
Chipset: VIA
BIOS String: 01/18/95-VT82C505-2A4L4000-00
BIOS Version: Award v4.50G Version 4.26gn2a (01/18/95)
From ZX Spectrum to IBM PS/2 30 and so on. http://asknotes.com/
Reply 88 of 191, by SSTV2
Manufacturer: ECS UM8810PAIO REV: 2.0.
Chipset:
UMC UM8886F, UM8881F - PCI SET;
UM82C865F+FDC37C665GT - I/O;
PCI0640B - IDE controller.
BIOS/Version: Award v4.50PG, VBS1.10H UM8810 ECS
BIOS string: 06/23/95-UMC-881/886-2A4X5E11-00
The attachment ECS.jpg is no longer available
The attachment POST.JPG is no longer available
The attachment LOGO.JPG is no longer available
The attachment VBS1.10H.zip is no longer available
Comments:
This BIOS version does not support PS/2 mouse, all routines and functions (IRQ12, INT15 function C1h, C2h, ETC.) responsible for PS/2 mouse data and resource handling are absent. Logo "HIGHSCREEN" at startup is animated.
Reply 89 of 191, by TheMobRules
Manufacturer/Identifier: MSI MS-4132 G ver. 1
Chipset: SiS 85C471/85C407
BIOS/Version: AMI 486DX ISA BIOS 08/08/93
BIOS String: 40-0100-001169-00101111-080893-SIS471B
The attachment MS4132G.zip is no longer available
The attachment MS4132G.jpg is no longer available
Reply 90 of 191, by zero01101
Manufacturer/Identifier: Silicon Valley Computer, Inc 486WB6A3.B1
Chipset: OPTi 82C493/392
BIOS/Version: AMI 486 BIOS ZZ342708, unknown version, BIOS string implies 1991-06-06
BIOS String: 40-0101-ZZ9999-00101111-060691-OPWBSX-F
Reply 91 of 191, by SSTV2
Manufacturer and model: Micronics JX30GP.
Motherboard P/N: 09-00189-10 REV B1.
Chipset:
MIC 471, MIC491;
PC87312VF - Super I/O.
BIOS/Version: Phoenix, 80486 ROM BIOS PLUS Version 0.10 GJX30G-04P, Gateway 2000 Local Bus BIOS.
BIOS date: 09/24/93.
The attachment PN_09-00189-10_REV_B1.jpg is no longer available
The attachment Micronics_GJX30G-04P_09-24-93.zip is no longer available
Comments:
MIC 471 is a rebranded SiS 85C460 or 85C461 386/486 single chip chipset, MIC491 - SiS 85C407 ISA bus buffer. G and P letters in model/BIOS stands for "Green" and "PS/2 mouse" respectively. BIOS supports power management and PS/2 mouse, but limits HDD geometry to 1024C/16H/63S, thus can't properly detect hard drives larger than 528MB. To enter BIOS setup CTRL+ALT+ESC key combination needs to be pressed after cache size is displayed during POST. Motherboards with P/N 09-00189-10 were used by Gateway.
Reply 92 of 191, by Predator99
Manufacturer/Identifier: Zida 4DVS
BIOS String: 40-07Z5-008031-00101111-121593-SIS471
http://www.win3x.org/uh19/motherboard/show/6881
The attachment 486-AB8068594.jpg is no longer available
The attachment 486-AB8068594.zip is no longer available
Reply 93 of 191, by Zalog
Manufacturer/Identifier: Amstrad PC9486
Chipset: UMC - UM82C481BF/UM82C482AF
Board Type - UX486VIO-A Rev. 1.0
BIOS/Version: AMI 486DX ISA BIOS 1993 - AA9222968
The attachment Amstrad_PC9486.zip is no longer available
Edit: 256K saved using SAVEROM
The attachment SAVEROM.zip is no longer available
The attachment PC9486_FULL_BOARD.JPG is no longer available
The attachment CLOSE_UP1.JPG is no longer available
The attachment CLOSE_UP2.JPG is no longer available
Edit: Added an image of the top 256k to capture video etc... BIOS
Reply 94 of 191, by evasive
@Zalog: Could you make a picture without the metal support in the middle? Or does that require full disassembly?
Reply 95 of 191, by Zalog
evasive wrote on 2021-04-07, 12:36:
Yes unfortunately it requires a fair degree of disassembly - fortunately I took one in the middle of an upgrade so if you don't mind shots of it that are slightly less clear (a bit harder to read the chips at the VGA end of the board) and in non-original condition (added cache chips, overdrive + extra ram) - find attached
The attachment PC9486_Upgrade.JPG is no longer available
Edit: BIOS String is: 40-0100-001131-00111111-111192-UMC480
Reply 96 of 191, by zoinknoise
FIC 486-GVT
VIA VT82C486, VIA VT82C482
AMIBIOS 08/08/93
The attachment IMG_3470.jpg is no longer available
Reply 97 of 191, by Predator99
Manufacturer/Identifier: ADI F4DXL-UC4
Chipset:
BIOS String:
http://www.win3x.org/uh19/motherboard/show/5495
The attachment 486-AB345213.jpg is no longer available
The attachment 486_AB345213.zip is no longer available
Reply 98 of 191, by Predator99
Manufacturer/Identifier: FIC 486-KVD
Chipset:
BIOS String:
http://www.win3x.org/uh19/motherboard/show/920
The attachment 486-AA9615811.jpg is no longer available
The attachment 486-AA9615811.zip is no longer available
Reply 99 of 191, by Jim5589
Horun wrote on 2020-12-28, 01:54:
#74 Motherboard: Amptron DX9200 AKA PcChips M915i with Fake cache Chipset: UMC UM8881F + UM8886BF EPROM: AMD AM27C010 BIOS Strin […]
with Fake cache
EPROM: AMD AM27C010
BIOS String: 41-p400-001437-00101111-101094-486AVIP-H
BIOS label: AMI 486DX ISA BIOS 1993
BIOS Version: AMI 10/10/1995: 11-08-1995
CRC 32bit Checksum: 82A4E810
Note: this Fake Cache bios is not same as the M915i BIOS 9151108s floating around.
http://www.win3x.org/uh19/motherboard/show/579
http://www.win3x.org/uh19/motherboard/show/5944
Included the 9151108s BIOS
Sorry if this is a stupid question but I am learning still. I have ended up with one of these boards with the fake cache on it. I plan to remove the fake cache and put some real stuff on it along with the jumpers to configure it. If I do this can I then put the bios on the unit from the links you have posted to make it work properly ?
