Quake2 + Acebot for DOSBox (128mb)
Reply 820 of 862, by Maraakate
Yeah, that's what I do. I always just set skill 0. Honestly a lot of the newer maps are so damn big with this whole what i like to call "contra style" wave of too many hard enemies all at the same time that I usually end up cheating at some point.
bind g god
forever in my autoexec.cfg 😁
Reply 821 of 862, by __ggorts
No luck yet in qdfitz. Also, had the bmodel error in qdos.
Reply 822 of 862, by Maraakate
bmodel error in qdos and qdosfx?
Reply 823 of 862, by __ggorts
Heh. I'll set up the bind. 😀
I noted the same trend with the map designers. It's taking one idea and running with it.
Reply 824 of 862, by __ggorts
bmodel error is just in qdos and I think it was alos in qdosfx.
Reply 825 of 862, by Maraakate
It's a trend with any game that allows level editing for the most part that has a community that's been on-going long since the game has ran out of steam for the average person. Everyone has played the game so many times to death they need some real challenge.
However, slightly off topic, but an excellent map pack for any game that I played a while ago was Death Wish for Blood. It's challenging on easy, but not enough where its enough to make me resort to cheating and honestly 100% the maps are above and beyond Monolith quality. It's 3 whole episodes too. Something to check out when you're getting tired of all the real 3d 😜
EDIT: verify the qdosfx error if you can. I think it said getspace overflow for me in qdosfx
Reply 826 of 862, by __ggorts
Qdosfx just loaded locust without problem. I don't know that I tried that combination before. I'll try telefragged.
Reply 827 of 862, by __ggorts
I'll definitely try that suggested map pack.
Qdosfx loads locust, but telefragged has the allowoverflowset error (as you noted!).
That's an interesting point about the community, it reminds of the Doom1 community and their very popular mod at moddb.
Reply 828 of 862, by Maraakate
Yeah. However Doom 2 had some cool stuff like Memento Mori, Requiem and Icarus. There is a Plutonium 2 that's recent but will run in vanilla doom and is somewhat hard (had to cheat a few times) but overall very nice.
Reply 829 of 862, by Maraakate
Also if you get NE2000 working in your dosbox builds we could play on my custom coop server on quakeworld. Or if you just want to "cheat" I do maintain a Windows port for debugging purposes but I maintain a binary on the QDOS homepage from time to time.
Reply 830 of 862, by __ggorts
Thanks for the guide. I'm always been a fan of Doom/2, especially the music.
Edit: thanks, I'll verify the ne2000 patch, but perhaps the windows port is in fact a better option.
Reply 831 of 862, by __ggorts
I tried to scan for the allowoverflowset error, but perhaps that's in another dir file or I have an older version!
Reply 832 of 862, by Maraakate
Speaking of Doom do you have private messaging I got something doom related for you.
Reply 833 of 862, by __ggorts
I have the pm active near my icon, I just realized the icon is there because I never noticed it before.
Reply 834 of 862, by __ggorts
I don't know if it's true, but the allowoverflow set error is similar to those caused by q2 mods. It must be more than just the parameters.
Reply 835 of 862, by Maraakate
PM sent.
Reply 836 of 862, by __ggorts
Thanks! I sent back a reply.
In any case with the above maps, I think many in the map packs should work and those two in question must have steeper system requirements. They are good tests for adding code bits.
Reply 837 of 862, by Maraakate
Also I found the problem with qdos and the telefragged bsp pushed a fix and will upload new binaries.
Reply 838 of 862, by __ggorts
Wonderful! I will definitely try that map pack now.
Reply 839 of 862, by Maraakate
You won't be able to play it in DOS unless you had a serious machine. I can barely hit 4-10 frames on that p3 and in software it can barely manage about the same. You could play it in software in windows, but I don't have fence textures so those grates on teh floor will be pink unless you modify the texture in the pak. Which I might end up doing for fun.
Anyways, quakespasm is really the best to be able to play that particular mod. Telefragged is really good actually.
