Socket A: Nvidia vs Via - battle of the platforms!
Reply 880 of 1055, by nd22
The test system is the same and represents the best of the best available for socket 462:
Abit AN7 - nforce2 ultra; Kingmax 2*1GB at 2.5-3-3-7 1T command rate; Leadtek geforce 7800gs, WD 150gb raptor. While there are more powerful AGP video cards such as geforce 7950gt I do not have them and already geforce 7800gs is bottlenecked by the CPU.
Software used: chipset driver version 5.10, graphics driver version 93.71, msi afterbuner 4.30, fraps 3.4.7, Everest (old name for what is today known as Aida 64) 5.50.
Reply 881 of 1055, by nd22
We go directly to the first benchmark which is Code creatures pro.
1. 1024*768 no AA, no sound:
Thoroughbred will always be first with the default Luna theme
Barton will always be second with the Royale theme
Reply 882 of 1055, by nd22
It seems I rushed to put up the results without presenting the screenshots with the systems details first so here they are:
Sempron 2800 - you can clearly see the processor being identified as Thoroughbred
Reply 883 of 1055, by nd22
... and Sempron 3000 - which is identified as Barton
Reply 884 of 1055, by nd22
2. Back to the benchmarks with Code creature pro again, at the same 1024*768 resolution and no AA but with sound:
- first is Sempron 2800
- second is Sempron 3000
Reply 885 of 1055, by nd22
3. We stay at 1024*768 but with AA 4x; no sound first time:
Sempron 2800
Sempron 3000
Reply 886 of 1055, by nd22
4. Same settings but with sound the second time:
Sempron 2800
Sempron 3000
Reply 887 of 1055, by nd22
5. We increase the resolution to 1280*1024, AA 4x, NO sound
Sempron 2800
Sempron 3000
Reply 888 of 1055, by nd22
6. At the same 1280*1024, AA4x but with sound we get the following average frame rates:
Sempron 2800
Sempron 3000
Reply 889 of 1055, by nd22
7. At the final 1600*1200 resolution we get exceptionally close frame rates:
Sound OFF
Sempron 2800
Sempron 3000
Reply 890 of 1055, by nd22
8. Same 1600*1200 AA 4x, sound ON. Practically identical results!
Sempron 2800
Sempron 3000
Reply 891 of 1055, by nd22
Barton is not off to a good start! There is a 1 -5% advantage over T-bird, within the margin of error, insufficient to distance itself!
Maybe we get different scores in Aquamark3, the next benchmark!
Reply 892 of 1055, by nd22
9. Aquamark3 at default settings - that means no AA, no sound. We are interested in the average frame rate and not the score!
Sempron 2800
Sempron 3000
Reply 893 of 1055, by nd22
10. Aquamark3 at the same 1024*768 resolution at maximum settings including sound
Sempron 2800
Sempron 3000
Reply 894 of 1055, by nd22
11. We go to 1280*1024 max settings, NO sound first:
Sempron 2800
Sempron 3000
Reply 895 of 1055, by nd22
12. We stay at 1280*1024 max settings and test with sound:
Sempron 2800
Sempron 3000
Reply 896 of 1055, by nd22
13. We reached the highest resolution: 1600*1200 max settings.
Sempron 2800
Sempron 3000
Reply 897 of 1055, by nd22
14. And the most demanding settings: 1600*1200 max + Sound ON
Sempron 2800
Sempron 3000
Reply 898 of 1055, by nd22
Things are looking pretty grim for the Barton! There is a 3.4 - 6.7% advantage however the difference in PR rating between Sempron 2800 and 3000 is 7.14%! Until now the PR of the 3000 does not seem justified!
Reply 899 of 1055, by nd22
15. We arrived at 3dmark and the first version to be tested is the 2000 one. Default settings - that means 16 bit color depth and 16 bit textures at 1024*768 resolution.
Sempron 2800
Sempron 3000
