Reply 920 of 1805, by RandomStranger
- Oldbie
pentiumspeed wrote on 2023-12-24, 18:19:I need to get your attention: Not supposed to spend using poor quality items for a data & VM server. […]
RandomStranger wrote on 2023-12-22, 16:04:Last week I've built the NAS I've been meaning to build for a while. An Intenso 128GB SSD for the OS, 3×6TB hard drives in RAID […]
RandomStranger wrote on 2023-12-16, 12:05:Modern hardware acquired, time to get into some modern activities!
Last week I've built the NAS I've been meaning to build for a while. An Intenso 128GB SSD for the OS, 3×6TB hard drives in RAID 5 for data storage on a Gigabyte GA-H61N-D2V with 8GB of DDR3-1600. All running OpenMediaVault 6.9
Initially I wanted to use a Celeron G550T, but ended up being underpowered so I intended to replace it with an I3-3220T. I just found one on a local trading site on Monday and arrived yesterday. Except the CPU I received was the plain i3-3220. Double checked the listing. It had the right model and the photos have also shown the T variant, so I issued a complaint. The plain variant I got has a 60% higher TDP and that matters when you run it 24/7 for years. The seller promised me a full refund, so we'll see what happens.
For the time being I'm using the i3 I got while keeping my eye open for a T variant.
Otherwise with the upgraded CPU performance it runs great and has plenty of power in reserve if I were to add features like cloud server functions, surveillance cams and smart home stuff.
IMG_20231216_141005.jpgIMG_20231216_141203.jpgIMG_20231216_141215.jpgIMG_20231216_174430.jpg
Not supposed to spend using poor quality items for a data & VM server.Intenso SSD is not good quality storage and cannot be trusted in your use case, these generic SSD in general fail often, performance issues. I always specify Samsung (not QVO), Micron, some Intel and Crucial and WD blue or black but not WD SA510 model (performance issues and poorly perceived quality.)
Thanks for the warning. I myself never had issues with Intenso flash storage media and user rewieves were good. It's only the OS that being stored on that drive and that's all there ever will be. It should barely be touched under normal circumstances and when it is, mostly for reading. I'll image it out of caution so if it ever fails restoration will be quick and clean.
