Reply 960 of 1168, by megatron-uk
Spent a bit of time cleaning the case of all the grime and scuffs, and it doesn't look too bad now:
Missing trim pieces around iLINK/audio connectors and the volume wheel/USB port:
There's also one hinge cover missing. I managed to get enough decent parts from both machines apart from that one.
Compared to the 'bigger brother' PCG-Fxxx machines, there's actually a more usable range of connectors on these ultra portables; two USB - 1x type A, 1x mini (plus a third if you include the iLINK breakout), and built-in Intel Pro/100 ethernet. Next up is figuring out how to get a USB floppy to work.... it's going to need a proprietary Sony one to boot, isn't it? I just know it....
Just for fun, here's a comparison with my smallest laptop - the Thinkpad 240:
Considering we're talking a 12" 1024x768 screen compared to a 10" 800x600... there's really not much in it. Both have extended battery modules installed - this makes the TP240 is a fraction thicker, whilst the Vaio is deeper front-to-back and a little heavier (the extended battery is most of that bulk).
https://www.target-earth.net
