Reply 980 of 1145, by maxtherabbit
- l33t
maxtherabbit wrote on 2023-10-16, 02:01:Maelgrum wrote on 2023-10-16, 01:39:From Duke Nukem 2:
D1 - Enable Speaker40 38 - Set Time Constant 5000 Hz75 15 09 - DMA DAC, 4-bit ADPCM ReferenceD0 - Halt DMA Operation, 8-bit40 38 - Set Time Constant 5000 Hz75 15 09 - DMA DAC, 4-bit ADPCM ReferenceD0 - Halt DMA Operation, 8-bit40 38 - Set Time Constant 5000 Hz75 15 09 - DMA DAC, 4-bit ADPCM ReferenceD0 - Halt DMA Operation, 8-bit40 72 - Set Time Constant 7042 Hz75 3E 05 - DMA DAC, 4-bit ADPCM ReferenceD0 - Halt DMA Operation, 8-bit40 39 - Set Time Constant 5025 Hz77 25 05 - DMA DAC, 2.6-bit ADPCM ReferenceD0 - Halt DMA Operation, 8-bit40 72 - Set Time Constant 7042 Hz75 3E 05 - DMA DAC, 4-bit ADPCM ReferenceD0 - Halt DMA Operation, 8-bit40 06 - Set Time Constant 4000 Hz75 3A 03 - DMA DAC, 4-bit ADPCM ReferenceD0 - Halt DMA Operation, 8-bitUses ADPCM 4 and 2.6 bit
So any "click build" testing we did with duke2 should be invalidated
This also means 4.16 should be retested with DOTT on a CT1740
